[GRASS5] Re: [GRASSLIST:6360] Startup Error GRASS60
Düster Horst wrote:
I try to start grass60 with the command grass60 and the following messages
appears:
[snip]
Error in startup script: couldn't read file
"/usr/local/grass-6.0.0/docs/nviz/help.tcl": no such file or dir
ectory
    while executing
That bug was introduced in:
  revision 1.9
  date: 2005/01/11 13:36:59; author: markus; state: Exp; lines: +34 -3
  added help button with Quick Intro
due to:
  @@ -27,6 +27,20 @@
   source $env(GISBASE)/etc/epsg_option.tcl
  +#HTML help
+source $env(GISBASE)/docs/nviz/help.tcl
  +proc make_help_window { w } {
  + frame $w
  + frame $w.f2
  + frame $w.f1
  + pack $w -side top -expand 1 -fill both
  + pack $w.f1 -side top -expand 1 -fill both
  + pack $w.f2 -side bottom -expand 0 -fill both
   proc searchGISRC { filename } {
     global database
NVIZ is supposed to be an optional component. Please remove the
reference to $env(GISBASE)/docs/nviz/help.tcl, and anything which
depends upon it, from gis_set.tcl.
On Sat, Apr 09, 2005 at 04:03:52AM +0100, Glynn Clements wrote:
> appears:
[snip]
> ectory
> while executing
  revision 1.9
due to:
  @@ -27,6 +27,20 @@
  +#HTML help
  + frame $w
  + frame $w.f2
  + frame $w.f1
     global database
Oh, I was sort of unaware of that.
Please remove the
Why not moving visualization/nviz/html/help.tcl
to a different place? I hesitate to remove the help text from
the startup screen.
> Please remove the
Will that file work without the rest of NVIZ?
I hesitate to remove the help text from the startup screen.
Help text is fine, but why the help text for NVIZ?
> > Please remove the
Yes, I think so. For me it does.
NVIZ offers help in its menu (see at the right).
It was implemented before we added HTML help to GRASS.
