The Cygwin binaries that Rich Greenwood kindly provided have a similar issue. NVIZ won't run unless there is a specific version of cygcrypt (that seems to accompany postgres) available.
Michael Barton
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
On May 14, 2004, at 4:02 PM, grass5-request@grass.itc.it wrote:
On Fri, May 14, 2004 at 11:18:12AM +0100, Glynn Clements wrote:
Markus Neteler wrote:
libcrypto.so.1 is needed by grass-5.3.0-1
probably due to PostGRESQL support?
This dependency is almost certainly bogus. The PostgreSQL modules
require libpq. If libpq happens to require libcrypto, then it is up to
the RPM which contains libpq to deal with that. GRASS shouldn't list
it as a dependency.libssl.so.1 is needed by grass-5.3.0-1
I guess due to PostgreSQL support.
In which case, this is also bogus.
Note that 'rpm -ba' has inserted these dependencies.
Anyway, I have defined some more dependencies, now a new
set of RPMs here:
http://mpa.itc.it/markus/grass53/rpms/Still OGDI is required since I don't know how to manage
two GDAL installations on one machine (my VMAP0/MapServer wants it).Markus
