Luca Palmeri <lpalmeri@ux1.unipd.it> wrote:
With CC I get the following error, right in the
beginning of compilation:
cc: Error: /export/venus6b/grass/src/src/include/gisdefs.h, line 278:
Invalid declaration.
int G_fatal_error(char *,...) __attribute__ ((__noreturn__));
I had to
exclude i.in.erdas due to the following error:
main.c:48: conflicting types for `swab'
These are both mine.
The __noreturn__ attribute was to keep -Wall happy while I was hunting
down missing return statements. It serves no other purpose. I think
that all of the missing return-s are now accounted for, so it's not
necessary to keep this around. Change that prototype back to:
int G_fatal_error(char *,...);
The i.in.erdas problem is something that I created to work around a
problem in my compiler. I should have fixed the egcs headers instead.
Delete the offending lines (45-49) and retry the compile.
i.in.erdas, as Angus said, is not usable on Alphas. There are alignment
issues with the data definition. It should compile cleanly, though.
Running it produces a segfault as it tries to use an ERDAS header that
has "only" 128 bytes.
Bill Hughes
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 1927
max: 0
