[GRASS5] Re: Open GRASS issues
(cc list)
On Wed, Jan 25, 2006 at 02:09:09PM +0000, Glynn Clements wrote:
Markus Neteler wrote:
> > > I would like to ask you for help with the zlib issue.
> > > For me it's a showstopper, also blocking 6.0.2.
> > > Do you see a chance to look into this?
> > Try the attached patch; it fixes your test case and a few similar
> > cases (e.g. 10x10, 9x9 etc, constant value).
> It happened for all maps below 13x13 (or 12x12, not tested).
> With your patch it's fixed.
> Will you submit it?
Done.
> It should also go into 6.0, right?
If GRASS_INT_ZLIB is present in 6.0.x, then the fix needs to go in.
Done.
But: It also exists in GRASS 5:
cvsgrass53> grep GRASS_INT_ZLIB ./src/libes/gis/opencell.c
        COMPRESSION_TYPE = getenv("GRASS_INT_ZLIB") ? 2 : 1;
http://freegis.org/cgi-bin/viewcvs.cgi/grass/src/libes/gis/put_row.c
I have tried locally:
patch -p2 < ~/zlib.patch
patching file put_row.c
'patch' doesn't complain. Should I submit (also for the next 5.4.x release
managed by Paul)?
On Wed, Jan 25, 2006 at 03:19:34PM +0100, Markus Neteler wrote:
(cc list)
> > Will you submit it?
> Done.
Done.
FreeGIS.org
managed by Paul)?
I have submitted the patch to GRASS 5-CVS as well.
