> - with d.pan and d.zoom the color of vectors is always restored white.
> If you draw a map with a e. g. green vector and zoom/pan, the vector is
> re-drawn, but always white instead of the initial green.
> There must be something wrong with the R_pad contents, as d.save puts
> out the correct color with the vector before calling d.zoom/d.pan, but
> afterwards the color is white even in the pad structure, so that d.save
> puts out "d.vect vect=vect@PERMANENT color=white".
That's not bug. It is intended behaviour.
If you want to recreate current window using d.zoom, use -r flag.
OK, the -r flag is not shown in the tcltkgrass module and in the
html-manpage. So i overlooked that.
But i still think that it is a bug (or at least an inconsitency) that
the window is redrawn with d.zoom/d.pan, but the color of the vector is
changed to white. I think that d.zoom/d.pan should either always redraw
the correct screen or don't redraw anything at all without the -r flag.
In that case the user can first use d.save, then d.zoom/d.pan and then
redraw the screen without waiting for the "wrong" redraw of
d.zoom/d.pan.
Just how i would like it.
d.pan is not implemented to recreate window, -r flag.
It would be nice if d.zoom and d.pan behave identically, otherwise it is
confusing.
subject 'unsubscribe grass5'
From neteler@geog.uni-hannover.de Mon Nov 27 02:38:49 2000
Date: Sun, 26 Nov 2000 18:00:45 +0100
To: GRASS <grass@geni.knu.ac.kr>
CC: grass5@geog.uni-hannover.de
Subject: Re: [GRASS5] some bugs
Hi Huidae,
thanks a lot for your answer.
d.zoom/d.pan.
Now implemented what you want.
confusing.
Absolutely you're right.
d.pan has some old code to be updated as soon as possible.
Huidae Cho
Despite the pessimism I managed to build Grass under Win 98 today.
First port of call was ps.map, as there is no graphical output under
Windows.
The following ps.map script doesn't produce the results I expected ie there
were no numbers on the grid lines and no copper values next to the sample
points, just small rectangles:
sites copper
color red
size 0.100000
desc y
end
scale 1:3000
grid 10
numbers 1
end
end
The red markers came out OK though.
I can send the ps file and the zipped location if you like.
Mike Thomas.
