[GRASS5] statistics in GRASS
Scott,
I already discarded the digest that had the original thread here, so I may be missing your point a bit. If so, sorry. The merge of r.average, r.median, and r.mode was already done in r.statistics. However, if you are talking about working with r.univar, that would be great.
Michael
On Friday, April 16, 2004, at 03:01 AM, grass5-request@grass.itc.it wrote:
Date: Thu Apr 15, 2004 1:32:43 PM America/Phoenix
To: Hamish <hamish_nospam@yahoo.com>
Cc: Markus Neteler <neteler@itc.it>, grass5@grass.itc.it
Subject: Re: [GRASS5] [bug #2380] (grass) unexpected '(' in r.univar
On Thu, 15 Apr 2004, Hamish wrote:
(Actually I think it was Markus who wrote:)
See also:
http://intevation.de/rt/webrt?serial_num=1848&display=History
"merge of r.average, r.median and r.mode"
To which Hamish said:
I can't do this now. Someone else?
Hamish
If nobody beats me to it (which would be fine!), I will be working on this
over the summer. I said "way back" that I wanted to tackle it, but
haven't found the time.
I'm glad to see the exchange and your work on r.univar, looking at that
code will probably really help.
Scott
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
The problem with r.statistics is that it's limited to integer data. The other three tools have been updated to floating point. I was going to start by making a floating point r.statistics with at least mean, median and mode, then work on getting other statistics in there too. I have another old module around that is very similar to r.statistics but with slightly different options available - it also started as integer only and I had started making it floating point compatible - then I discovered these other modules and wanted to stop reinventing the wheel.
On Apr 16, 2004, at 13:16, Michael Barton wrote:
Scott,
Michael
See also:
Hamish
Scott
USA
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Scott Mitchell, Assistant Professor, Carleton University
Department of Geography & Environmental Studies, Loeb A209
Mailing: Loeb B349, 1125 Colonel By Dr., Ottawa, ON K1S 5B6 Canada
1-613-520-2600 x2695 Fax: 613-520-4301 Scott_Mitchell@carleton.ca
