[GRASS5] Tcl/Tk config on Linux??
greetings - I did a fresh CVS checkout of the grass sources, and am trying to *just* get past the "configure" script :frowning:
I downloaded/built the Tck/Tk source packages, "cd unix; configure;make; makeinstall" -- no problems. Everything appears to have installed just fine in /usr/local .
But I keep getting "Unable to locate Tk includes"... :frowning:
And the #$%^ing include files are there!!
Before mercilessly hacking the configure script, thought I should ask this alias...
ideas/suggestions welcomed!
thanks!
Chris
./configure --with-tcltk-includes=/usr/local/include
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
...(blah..blah...)
checking for location of Tcl/Tk includes... /usr/local/include
checking for tcl.h... yes
checking for tk.h... no
configure: error: *** Unable to locate Tk includes.
[root@gateway2earth grass]
[root@gateway2earth grass]% ls /usr/local/include/*tk*
/usr/local/include/tkDecls.h /usr/local/include/tk.h /usr/local/include/tkPlatDecls.h
Look for relevant entries in the config.log file. Something in there
should indicate why the check failed.
Note that header checks don't simply check for the existence of a
named file. They attempt to compile (or, to be precise, preprocess) a
C file which includes that header. If the compilation generates any
output (including warnings), the check fails.
