[GRASS5] v.digit colors
Could anyone give me a quick rundown on the different line, boundary, node, and centroid colors in v.digit 6.1.cvs?
Kirk
The colors are described on symbology tab in settings.
Radim
Kirk
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Radim,
I would like to hear your thoughts concerning what appears to be fairly odd behavior in v.digit. First some background.
I am working with some vectors that were digitized by students using ESRI products. The students then saved their work as shape files. I am double checking their work and using v.digit (6.1.cvs) to make a few edits (where my interpretation is a little different from theirs) and add attributes to areas.
The vector is connected to a single table in postgresql.
In 90% of the cases were I select a centroid, or line, or an area, the expected results get printed to for form which pop up.
However, in a few cases, when I select a centroid, the form pops up with 3 tabs at the top (Layer 1, Layer 1, Layer2)
The two layer 1 tabs will different information in the fields (including different cat values), and the layer 2 tab, says "Database connection not defined"
g.list shows the vector name to be "test",
v.info shows 1 dblink. and the -c option shows:
GRASS 6.1.cvs (minnesota_utm):~ > v.info -c test
Displaying column types/names for database connection of layer 1:
INTEGER|cat
INTEGER|id
CHARACTER|type
CHARACTER|class
GRASS 6.1.cvs (minnesota_utm):~ > v.info -c test layer=2
Displaying column types/names for database connection of layer 2:
ERROR: Database connection not defined
Any idea what might have happened? or how to get rid of the ghost layer1?
Kirk
On 3/3/06, Kirk R. Wythers <kwythers@umn.edu> wrote:
Radim,
This is all correct. v.in.ogr must clean the topology but it
preserves all input data. In this case there were 2 overlaping
areas in the input. GRASS created one topologicaly clean
area (without overlaps) linked to 2 records (original attributes of
the 2 areas). Those are the 2 tabs for Layer 1.
Because this happens quite often when a shapefile is imported
and in most cases it means errors (overlaps) in input data
v.in.ogr adds for convenience a new layer 2 with number
of categories in Layer 1. Using Layer 2 it is very easy
to visualize and identify all errors in the input data.
Radim
INTEGER|cat
INTEGER|id
CHARACTER|type
CHARACTER|class
layer1?
Kirk
Radim,
Radim
Thanks Radim,
In this case, one of the "Layer 1s" is just plain wrong and the best thing to do is delete it. I thought to use db.droptable, but that command is not available (has it been removed?). Additionally, since the second Layer 1 is not a "real" table in postgres. I don't see that it would work anyway.
I think the question here is... Is there a way to correct someone else's accidental double coding of a polygon by removing the offending layer?
Kirk
INTEGER|cat
INTEGER|id
CHARACTER|type
CHARACTER|class
layer1?
Kirk
>> Radim,
> Radim
Thanks Radim,
There is onle ONE layer 1, but TWO records.
You just need to delete the record and category
on the centroid using 'Delete' button in 'Display categories'
windows or 'Delete' button in attibutes windows in QGIS.
Radim
offending layer?
Kirk
>> INTEGER|cat
>> INTEGER|id
>> CHARACTER|type
>> CHARACTER|class
>> layer1?
>> Thanks,
>> Kirk
on the centroid using ‘Delete’ button in ‘Display categories’
windows or ‘Delete’ button in attibutes windows in QGIS.
Radim
Thanks again Radim. With your patient explanations, I am finally starting to understand this stuff (and better yet, fix problems that were created when I or someone else did not understand this stuff).
Kirk
