[GRASS5] v.extracts dissolve option broken?
Dear list,
I would like to dissolve some geometries, but apparently v.extract -d
seems to be broken. It does not dissolve the boundaries with the same
attribute.
Is this a userfault or something inside the module?
v.extract -d in=data out=pieceofdata_dis where="col1 = 'labeltext'"
Thank you for your help
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
Hello Stephan,
On Sat, 11 Mar 2006 16:29:36 +0100 Stephan Holl <holl@gdf-hannover.de>
wrote:
Dear list,
attribute.
Classical Usererror. I found out that the list-parameter in combination
with the new=-parameter is needed. Otherwise dissolve will not work.
Sorry for making unnessessary noise...
Stephan
Stephan,
v.extract -d works (for me) on areas. Can you post
v.info pieceofdata_dis
? Maybe there is a vector type issue.
On Sat, Mar 11, 2006 at 04:29:36PM +0100, Stephan Holl wrote:
Dear list,
attribute.
  Stephan
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
