[GRASS5] v.in.ogr behaviour
Dear list,
[sorry for crossposting, but perhaps this is interesting for the
GDAL-folks as well]
I am working with GRASS6_CVS and Oracle 9i which is compiled into
GDAL/OGR 1.3.1. Everything works if the tables in Oracle are owned by
the given user.
v.in.ogr reports the available layers as follows:
v.in.ogr -l dsn="OCI:owneroftables/pw@OCI" layer=DATA1 out=data1
Data source contains 2 layers:
DATA1, DATA2
Removing the -l-switch imports the data nicly and creates dataset data1
inside GRASS.
When I create another oracle-user with only
SELECT-privileges on that table, the tables inside Oracle are shown like
this:
v.in.ogr -l dsn="OCI:readonlyuser/pw@OCI" layer=OWNEROFTABLES.DATA1
out=data1
OWNEROFTABLES.DATA1, OWNEROFTABLES.DATA2
Trying to import now, this results in a Segmentation fault.
v.in.ogr dsn="OCI:readonlyuser/pw@OCI" layer=OWNEROFTABLES.DATA1
out=data1
So I assume the dot between user and table produces this?! Perhaps
anybody can give me a hint where to look at.
Using ogr2ogr works with both users and exports e.g. a shapefile
correct.
Thanks in advance for any pointers.
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
Hello Lists,
[crosspost again]
On Mon, 13 Mar 2006 12:09:15 +0100 Stephan Holl <holl@gdf-hannover.de>
wrote:
Dear list,
GDAL-folks as well]
the given user.
DATA1, DATA2
data1 inside GRASS.
like this:
out=data1
out=data1
correct.
Apparently noone has stumbled over this I will provide as much
information for the developers.
I have created a full gdb backtrace[1] of the segfault. But again, I do
not know where to dig into the problem since I do know what is going on
there...
Thank you for having a look what might go wrong here.
Best regards
  Stephan
[1] http://www.gdf-hannover.de/holl/tmp/v.in.ogr_bt-full.txt
Hello Stephan,
[replying to myself again]
On Wed, 15 Mar 2006 09:37:26 +0100 Stephan Holl <holl@gdf-hannover.de>
wrote:
Hello Lists,
[crosspost again]
wrote:
> Dear list,
> GDAL-folks as well]
> by the given user.
> DATA1, DATA2
> data1 inside GRASS.
> like this:
> out=data1
> out=data1
> correct.
do not know where to dig into the problem since I do know what is
going on there...
Learning to use DDD with Markus help got further information for me.
When I run v.in.ogr through ddd I have severel stacks which can be
investigated.
1.UP: key_value1.c:107
2.UP: key_value4.c:49
3.UP: convert.c:352
4.UP: /v.in.ogr/main.c:384
It currently segfaults in key_value1.c:107 (strcmp).
When I put the lines into comments, recompile and run v.in.ogr with
-o-flag, the dataset gets imported with warning, at least it gets
imported.
So now I know, that there must be something wrong with the
projection-stuff. It seems to me that Markus has investigated something
similar in the bugtracker[1] also dealing with projection-stuff.
I have tried to find some hints in the CVS changelogs for key_value1.c
but I am not sure if they are relevant.
2006-01-04 12:40 markus G_malloc(); alloc() -> G_alloc(); calloc() ->
    G_calloc();realloc() -> G_realloc()
and
2006-02-09 04:08 glynn Use <grass/gis.h> etc rather than <gis.h>
Probably this problem is also relevant with the following changes:
2006-02-12 22:41 cho v.in.ogr segmentation fault fixed
          argument type fixed: OGRSpatialReferenceH * =>
          OGRSpatialReferenceH OGRSpatialReferenceH is already a
          pointer to void.
2006-02-09 17:58 cho vector/v.in.ogr/main.c: bug fixed: wrong argument
type passed
Does anybody know if this changes require any CVS-versions of GDAL/OGR
or PROJ.4?
Thanks for any comments on this.
  Stephan
[1] https://intevation.de/rt/webrt?display=History&serial_num=4190
Hello Stephan,
On Wed, 22 Mar 2006 11:10:58 +0100 Stephan Holl <holl@gdf-hannover.de>
wrote:
Hello Stephan,
wrote:
> Hello Lists,
> [crosspost again]
> <holl@gdf-hannover.de> wrote:
> > Dear list,
> > GDAL-folks as well]
> > by the given user.
> > DATA1, DATA2
> > data1 inside GRASS.
> > shown like this:
> > layer=OWNEROFTABLES.DATA1 out=data1
> > out=data1
> > correct.
> going on there...
investigated.
3.UP: convert.c:352
imported.
something similar in the bugtracker[1] also dealing with
projection-stuff.
and
already a pointer to void.
argument type passed
or PROJ.4?
OK, further updates. I have started over with a fresh checkout of
GRASS today, and noticed, that the nasty segfault-bug in v.in.ogr is
still there.
What I am curious is, that a fix from Cho[1] from 2006-02-09 is not in
CVS. I can see the commit-mail, where it gets included[1], but when
I do cvs diff to look where it gets lost again, I cannot find the
revision...
When I add this manuall, recompile the module, v.in.ogr
does not segfault anymore, but does not determine the correct projection
information of the dataset in any case...
I have stripped down a spearfish-example where you can reproduce this.
1. Applying the patch from attachment (and recompile v.in.ogr)
2. start grass in spearfish-location
3. export soils dataset to shape
   v.out.ogr in=soils type=area dsn=/tmp/ olayer=soils
4. show projection of shape
   ogrinfo -ro -al -summary /tmp/soils.shp
Layer name: soils
Geometry: Polygon
Feature Count: 737
Extent: (589443.780000, 4913923.480000) - (609546.170000,
4928105.880000)
Layer SRS WKT:
PROJCS["UTM Zone 13, Northern Hemisphere",
    GEOGCS["clark66",
        DATUM["North_American_Datum_1927",
            SPHEROID["clark66",6378206.4,294.9786982]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-105],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["meter",1]]
cat: Real (11.0)
label: String (80.0)
seems OK so far.
5. try to reimport from shape
   v.in.ogr dsn=/tmp/soils.shp out=test1
ERROR: Projection of dataset does not appear to match current location.
       LOCATION PROJ_INFO is:
       datum: nad27
       nadgrids: conus
       proj: utm
       ellps: clark66
       a: 6378206.4000000004
       es: 0.0067686580
       f: 294.9786982000
       zone: 13
       cellhd.proj = 0 (unreferenced/unknown)
       You can use the -o flag to v.in.ogr to override this check.
       Consider to generate a new location with 'location' parameter
       from input data set.
Can anybody reproduce this?
if I do not apply this patch, the shapefile gets imported, but I can
import any projected data, every data gets accepted and it seems that
the -o switch is given.
I think, there is something is wrong inside the
projection/datum-recognition.
Thank you for looking into this.
cheers
  Stephan
[1] http://grass.itc.it/pipermail/grass-commit/2006-February/020656.html
I'm unable to reproduce your error using GRASS 61. cvs updated today,
nor a segfault. Does it help you? Trace follows:
GRASS 6.1.cvs (spearfish60):~ > v.out.ogr in=soils type=area dsn=/tmp/
olayer=soils
Exporting 737 areas (may take some time) ...
100%
737 features written
WARNING: 1 features without attributes written
GRASS 6.1.cvs (spearfish60):~ > v.in.ogr dsn=/tmp/soils.shp out=test1
A datum name nad27 (North_American_Datum_1927) was specified without
transformation parameters.
WARNING: Non-interactive mode: the GRASS default for nad27 is
         towgs84=-22.000,157.000,176.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: soils
WARNING: Column name changed: 'cat' -> 'cat_'
Importing map 737 features...
Building topology ...
778 primitives registered
Building areas: 100%
534 areas built
529 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built.
Number of nodes : 652
Number of primitives: 778
Number of points : 0
Number of lines : 0
Number of boundaries: 778
Number of centroids : 0
Number of areas : 534
Number of isles : 529
Number of incorrect boundaries : 247
Number of areas without centroid : 534
WARNING: Cleaning polygons, result is not guaranteed!
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Registering points ... 34778
All points (vertices): 71509
Registered points (unique coordinates): 34778
Points marked for break: 1418
Breaks: 4008
Remove duplicates:
Duplicates: 1965
Break boundaries:
Intersections: 0
Remove duplicates:
Duplicates: 0
Clean boundaries at nodes:
Modifications: 0
Change dangles to lines:
Removed dangles: 0 removed lines: 0
Remove bridges:
Removed bridges: 0 removed lines: 0
737 areas built
42 isles built
Topology was built.
Number of nodes : 1418
Number of primitives: 4786
Number of lines : 0
Number of boundaries: 4786
Number of areas : 737
Number of isles : 42
Number of areas without centroid : 737
Layer: soils
2850 primitives registered
737 areas built
42 isles built
Topology was built.
Number of nodes : 2155
Number of primitives: 2850
Number of lines : 0
Number of boundaries: 2113
Number of centroids : 737
737 input polygons
total area: 2.762475e+08 (737 areas)
overlapping area: 0.000000e+00 (0 areas)
area without category: 0.000000e+00 (0 areas)
M.
2006/3/23, Stephan Holl <holl@gdf-hannover.de>:
Hello Stephan,
wrote:
> Hello Stephan,
> wrote:
> > Hello Lists,
> > [crosspost again]
> > > Dear list,
> > > GDAL-folks as well]
> > > by the given user.
> > > DATA1, DATA2
> > > data1 inside GRASS.
> > > shown like this:
> > > out=data1
> > > correct.
> > going on there...
> investigated.
> 3.UP: convert.c:352
> imported.
> projection-stuff.
> and
> or PROJ.4?
still there.
revision...
Layer name: soils
Geometry: Polygon
Feature Count: 737
4928105.880000)
Layer SRS WKT:
    GEOGCS["clark66",
    UNIT["meter",1]]
cat: Real (11.0)
seems OK so far.
       datum: nad27
       nadgrids: conus
       proj: utm
       ellps: clark66
       es: 0.0067686580
       f: 294.9786982000
       zone: 13
cheers
        Stephan
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
-- marcos boullón magán
-- universidade de Santiago de Compostela
Hello marcos,
On Thu, 23 Mar 2006 12:31:43 +0100 "marcos boullón magán"
<marcosboullon@gmail.com> wrote:
OK, thanks for your report.
I just realized that I have forgotten to attach the small patch.
Could you try with the patch again (which should be in CVS already when
I look at the changelogs).
Thanks for testing.
  Stephan
olayer=soils
100%
Layer: soils
534 areas built
529 isles built
Topology was built.
Number of lines : 0
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Breaks: 4008
Remove duplicates:
Duplicates: 1965
Break boundaries:
Intersections: 0
Remove duplicates:
Duplicates: 0
Modifications: 0
Remove bridges:
737 areas built
42 isles built
Topology was built.
Number of lines : 0
Layer: soils
737 areas built
42 isles built
Topology was built.
Number of lines : 0
737 input polygons
M.
> Hello Stephan,
> > Hello Stephan,
> > > Hello Lists,
> > > [crosspost again]
> > > > Dear list,
> > > > the GDAL-folks as well]
> > > > into GDAL/OGR 1.3.1. Everything works if the tables in Oracle
> > > > are owned by the given user.
> > > > out=data1 Data source contains 2 layers:
> > > > DATA1, DATA2
> > > > dataset data1 inside GRASS.
> > > > shown like this:
> > > > Perhaps anybody can give me a hint where to look at.
> > > > shapefile correct.
> > > again, I do not know where to dig into the problem since I do
> > > know what is going on there...
> > me. When I run v.in.ogr through ddd I have severel stacks which
> > can be investigated.
> > 3.UP: convert.c:352
> > with -o-flag, the dataset gets imported with warning, at least it
> > gets imported.
> > projection-stuff.
> > key_value1.c but I am not sure if they are relevant.
> > calloc() -> G_calloc();realloc() -> G_realloc()
> > and
> > GDAL/OGR or PROJ.4?
> still there.
> not in CVS. I can see the commit-mail, where it gets included[1],
> but when I do cvs diff to look where it gets lost again, I cannot
> find the revision...
> projection information of the dataset in any case...
> this.
> Layer name: soils
> Geometry: Polygon
> Feature Count: 737
> 4928105.880000)
> Layer SRS WKT:
> GEOGCS["clark66",
> UNIT["meter",1]]
> cat: Real (11.0)
> seems OK so far.
> location.
> datum: nad27
> nadgrids: conus
> proj: utm
> ellps: clark66
> es: 0.0067686580
> f: 294.9786982000
> zone: 13
> that the -o switch is given.
> cheers
> Stephan
> [1]
> sensing Hannover Office - Mengendamm 16d -
> D-30177 Hannover Internet: www.gdf-hannover.de - Email:
> holl@gdf-hannover.de Phone : ++49-(0)511.39088507 -
> grass5 mailing list
> grass5@grass.itc.it
(attachments)
cho.patch (1.05 KB)
Hello Stephan,
After applying the patch, the output is:
marcos@venux:~/cvsgrass$ cd grass6/vector/v.in.ogr/
marcos@venux:~/cvsgrass/grass6/vector/v.in.ogr$ patch < ~/cho.patch
marcos@venux:~/cvsgrass/grass6/vector/v.in.ogr$ make
marcos@venux:~/cvsgrass/grass6/vector/v.in.ogr$ cd ../..
marcos@venux:~/cvsgrass/grass6/vector/v.in.ogr$ su
venux:/home/marcos/cvsgrass/grass6/vector/v.in.ogr# make install
marcos@venux:~/cvsgrass/grass6/vector/v.in.ogr$ grass61
GRASS 6.1.cvs (spearfish60):~/cvsgrass/grass6/vector/v.in.ogr >
100%
       datum: nad27
       nadgrids: conus
       proj: utm
       ellps: clark66
       es: 0.0067686580
       f: 294.9786982000
       zone: 13
       Consider to generate a new location with 'location' parameter from
       input data set.
M.
Hello marcos,
> Hi,
Thanks for testing.
        Stephan
> olayer=soils
> 100%
> Layer: soils
> 534 areas built
> 529 isles built
> Topology was built.
> Number of lines : 0
> Topology was built.
> Number of lines : 0
> Number of areas : -
> Number of isles : -
> Break polygons:
> Breaks: 4008
> Remove duplicates:
> Duplicates: 1965
> Break boundaries:
> Intersections: 0
> Remove duplicates:
> Duplicates: 0
> Modifications: 0
> Remove bridges:
> 737 areas built
> 42 isles built
> Topology was built.
> Number of lines : 0
> Layer: soils
> 737 areas built
> 42 isles built
> Topology was built.
> Number of lines : 0
> 737 input polygons
> M.
> > Hello Stephan,
> > > Hello Stephan,
> > > > Hello Lists,
> > > > [crosspost again]
> > > > > Dear list,
> > > > > DATA1, DATA2
> > > > > shown like this:
> > > > > shapefile correct.
> > > 3.UP: convert.c:352
> > > gets imported.
> > > projection-stuff.
> > > and
> > > GDAL/OGR or PROJ.4?
> > still there.
> > this.
> > Layer name: soils
> > Geometry: Polygon
> > Feature Count: 737
> > 4928105.880000)
> > Layer SRS WKT:
> > GEOGCS["clark66",
> > UNIT["meter",1]]
> > cat: Real (11.0)
> > seems OK so far.
> > location.
> > datum: nad27
> > nadgrids: conus
> > proj: utm
> > ellps: clark66
> > es: 0.0067686580
> > f: 294.9786982000
> > zone: 13
> > cheers
> > Stephan
> > [1]
> > _______________________________________________
> > grass5 mailing list
> > grass5@grass.itc.it
Oops. Transcription error! Steps were...
marcos@venux:~/cvsgrass/grass6$ su
venux:/home/marcos/cvsgrass/grass6# make install
marcos@venux:~/cvsgrass/grass6$ grass61
So, don't worry: patch was applied, command recompiled and
successfully installed.
M.
Hello marcos,
On Thu, 23 Mar 2006 13:01:54 +0100 "marcos boullón magán"
Hello Stephan,
100%
location.
       datum: nad27
       nadgrids: conus
       proj: utm
       ellps: clark66
       es: 0.0067686580
       f: 294.9786982000
       zone: 13
This is what I recognize as well. So where to look for the error now?
Perhaps someone with more knowledge about the projection/datum-stuff
could investigate the code?
Thank you
  Stephan
Hi Stephan,
Sorry, but it seems that Cho's patch is not correct.
In file lib/proj/convert.c, line 227, the definition of
GPJ_osr_to_grass() states that fourth parameter is type
"OGRSpatialReferenceH", not "OGRSpatialReferenceH *" (a value, not a
pointer to the value):
int GPJ_osr_to_grass(struct Cell_head *cellhd, struct Key_Value **projinfo,
                     struct Key_Value **projunits, OGRSpatialReferenceH hSRS,
                     int interactive)
In file vector/v.in.ogr/main.c, line 384, the cvs code does a correct
use of this function:
        if ( GPJ_osr_to_grass( &cellhd, &proj_info,
                               &proj_units, Ogr_projection, 0) < 0 )
The patch incorrectly sends a pointer to the Ogr_projection variable
(of type OGRSpatialReferenceH) insted of the actual value as fourth
parameter:
                               &proj_units, &Ogr_projection, 0) < 0 )
When the patch is applied --wrong datatype is used--
GPJ_osr_to_grass() fails to identify the reference system: file
lib/proj/convert.c, line 248 (no Geographic coord system, nor
Projected, then it assumes coord system is Projected XY) and you get
the error message "ERROR: Projection of dataset does not appear to
match current location. [...] cellhd.proj = 0 (unreferenced/unknown)".
In conclussion, patch is incorrect.
If you still get segfaults with GRASS cvs version, I'm afraid the
problem is not related to this. (Try an interative debugging to find
in which function it fails, then check which parameter produces the
crash and follow back its assignements).
Hope you can solve it. Regards,
M.
Hello marcos,
> Hello Stephan,
> 100%
> location.
> datum: nad27
> nadgrids: conus
> proj: utm
> ellps: clark66
> es: 0.0067686580
> f: 294.9786982000
> zone: 13
Thank you
        Stephan
Hello again,
If you are still receiving a segfault with GRASS 6.1 cvs version in
file lib/gis/key_value1.c, line 107, as said in a previous email, you
can try the following patch (attached) to gather more information on
the error conditions (but don't apply the Chos's patch!).
The patch containts code to show the comparing strings process while
running in G_find_key_value() function. Patch and compile as
necessary, then in GRASS try v.out.ogr/v.in.ogr and compare your
results with the attached ones:
$ cd grass6/lib/gis
$ patch < key_vect1.patch
GRASS 6.1.cvs (spearfish60):~/cvsgrass/grass6 > v.out.ogr in=soils
type=area dsn=/tmp/ olayer=soils 2> v.out.ogr.stderr.txt
GRASS 6.1.cvs (spearfish60):~/cvsgrass/grass6 > md5sum /tmp/soils.shp
24a6c8a36089cfd661b417807546f8ba /tmp/soils.shp
GRASS 6.1.cvs (spearfish60):~/cvsgrass/grass6 > v.in.ogr
dsn=/tmp/soils.shp out=test1 2> v.in.ogr.stderr.txt
If not succesfully finished, v.in.ogr.stderr.txt containts the
"trace". Compare with mine and report.
Good luck,
M.
2006/3/23, marcos boullón magán <marcosboullon@gmail.com>:
Hi Stephan,
                     int interactive)
parameter:
M.
> Hello marcos,
> > Hello Stephan,
> > 100%
> > location.
> > datum: nad27
> > nadgrids: conus
> > proj: utm
> > ellps: clark66
> > es: 0.0067686580
> > f: 294.9786982000
> > zone: 13
> Thank you
> Stephan
(attachments)
key_value1.zip (8.15 KB)
Hello marcos boullón magán,
On Thu, 23 Mar 2006 17:10:45 +0100 "marcos boullón magán"
Hello again,
Thank you very much for your clear and very helpful explanation of what
was going in chos patch.
As I am now C-expert, it is now possible to understand the differences
between the two decalarations.
$ cd grass6/lib/gis
I have applied your patch and have the same behviour as yours with the
shapefile. The import works well.
BUT:
Using other datasources are getting more difficult.
I have a PostGIS-Point-dataset (EPSG:4326 -> latlon)
ogrinfo -al -summary "PG:dbname=postgis user=gdf" grass_users
INFO: Open of `PG:dbname=postgis user=gdf'
using driver `PostgreSQL' successful.
Layer name: grass_users
Geometry: Point
Feature Count: 32
Extent: (-155.605011, -77.280006) - (128.640015, 75.840004)
Layer SRS WKT:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.01745329251994328,
        AUTHORITY["EPSG","9122"]],
    AUTHORITY["EPSG","4326"]]
gid: Integer (0.0)
x: Integer (0.0)
y: Integer (0.0)
company: String (0.0)
which imports just fine into spearfish60 ?! This is aparently wrong.
Please see the debugging output attached (v.in.ogr_pgis.dmp).
So apparently GRASS identifies the dataset as utm (which is not true
as shown above from ogrinfo).
I have found another strange behaviour when trying to access
oracle-spatial through v.in.ogr. ogrinfo reports the correct
projection-information, but v.in.ogr segfaults while trying to compare
(null) -> segfault. (see v.in.ogr_oracle.dmp)
ogrinfo -al -summary -ro "OCI:user/pw@oracle.galileo"
DATA.SPEAR_SOILS
using driver `OCI' successful.
Layer name: DATA.SPEAR_SOILS
Geometry: Unknown (any)
Feature Count: 737
4928105.880000) Layer SRS WKT:
    GEOGCS["clark66",
        UNIT["Decimal Degree",0.0174532925199433]],
    UNIT["Meter",1]]
cat: Integer (11.0)
At least for other datasources than shapefiles some
projection-quirks are there.
Your help is greatly appreciated.
Thank you very much.
  Stephan
(attachments)
v.in.ogr_oracle.dmp (98 Bytes)
v.in.ogr.pgis.dmp (2.64 KB)
2006/3/24, Stephan Holl <holl@gdf-hannover.de>:
Sorry, but my skills in geoprocessing are rather low. I'm a recent
arrival to this field and get lost easily with projection, datum,
coord system... vocabulary. Maybe with an equivalent sample database I
could reproduce and trace back this error to the origin, maybe not.
Which SQL commands create point geometry datasets in EPSG:4326 latlon?
Anyway, as seen in dump, the importing driver finds the token "utm" in
the string returned by OSRExportToProj4() function call (file
lib/proj/convert.c, line 277), commented as "Get the coordinate system
definition in PROJ.4 format". Reference system appears as utm before
the conversion code. Did you double check you were importing the right
table? Sorry, no more ideas without all data.
Again, not enough data to say what's wrong with the import process:
apparently the key value in struct Key_Value is incorrect because null
value (file key_value1.c, line 107); going back to its last
assignement (incarnated as pszProj in file lib/proj/convert.c, line
675 I guess), it was... NULL: string pszProj is only different to NULL
when token "proj=something" is present in OSRExportToProj4() return
string.
Please add the following code to show what OSRExportToProj4() does (no
diff file because a single change). In file grass6/lib/convert.c, line
277 and 278, change
    if( OSRExportToProj4( hSRS, &pszProj4 ) != OGRERR_NONE )
        goto default_to_xy;
to
        goto default_to_xy;
    fprintf(stderr, "OSRExportToProj4() returned \"%s\"\n", pszProj4);
    fflush(stderr);
and recompile. Maybe useful info arises.
M.
revision...
see rev 1.57, 1.58. Applied then reverted.
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/vector/v.in.ogr/main.c
Hamish
Hello marcos,
On Fri, 24 Mar 2006 15:32:14 +0100 "marcos boullón magán"
OK, I could provide another dataset for you as SQL-Dump, which is in
EPSG:4326 for postGIS.
I put it on my website for you to download[1] (4 MB), a world-dataset
grabbed from here[2]. You could import the data using
psql -U <youuser> -h <yourhost> postgisdatabase < cntr98.sql (You need
a postgis-enabled database of course).
Yes, strange. After your patch was applied I got this output:
v.in.ogr dsn="PG:dbname=postgis user=gdf" layer=cntry98 out=test14
comparing "meters"
to "unit"
to "units"
to "meters"
OSRExportToProj4() returned "+proj=utm +zone=13 +ellps=clrk66
+datum=NAD27 +units=m +no_defs "
According to the ogrinfo-output the projection should at least be
EPSG 4326 which is latlon
ogrinfo -al -summary "PG:dbname=postgis user=gdf" cntry98
Layer name: cntry98
Geometry: Multi Polygon
Feature Count: 251
Extent: (-180.000000, -90.000000) - (180.000000, 83.623596)
Layer SRS WKT:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
gid: Integer (0.0)
fips_cntry: String (0.0)
gmi_cntry: String (0.0)
iso_2digit: String (0.0)
iso_3digit: String (0.0)
cntry_name: String (0.0)
sovereign: String (0.0)
pop_cntry: Integer (0.0)
sqkm_cntry: Real (0.0)
sqmi_cntry: Real (0.0)
curr_type: String (0.0)
curr_code: String (0.0)
landlocked: String (0.0)
color_map: String (0.0)
Which is definetly the projection of the current location I am in, and
not the data-projection.
g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 5345694.68966235
south: 5324945.25464811
west: 4452539.52677299
east: 4479502.31502616
nsres: 29.89832135
ewres: 29.92540317
rows: 694
cols: 901
I do not understand what is going on in there, so I need to leave this
to you and others to find out. *?!*
> compare (null) -> segfault. (see v.in.ogr_oracle.dmp)
string.
I see, so my Oracle_dataset does not provide the correct proj-string
apparently, which is quite strange, because ogr2ogr shows everything is
correct... See my last mail for ogrinfo-output.
The segfault somes from here:
comparing "meters"
to "unit"
to "units"
to "meters"
OSRExportToProj4() returned "+ellps=bessel +units=m +no_defs "
comparing "(null)"
to "ll"
Segmentation fault
So comparing (null) to something results in a segfault...
277 and 278, change
        goto default_to_xy;
to
        goto default_to_xy;
    fflush(stderr);
Yes, definetly. Thank you.
Best
  Stephan
[1] http://www.gdf-hannover.de/holl/tmp/cntry98.sql.gz
[2] http://www.mappinghacks.com/data/cntry98.zip
Hello Hamish,
On Sat, 25 Mar 2006 02:33:18 +1200 Hamish <hamish_nospam@yahoo.com>
thanks
  Stephan
Hello Stephan,
Our outputs differ again!
comparing "meters"
to "unit"
to "units"
to "meters"
Very strange, because program flow shouldn't arrive to OSRExportToProj4()!!
I downloaded the db you provided, EPSG 4326 latlon, successfully
imported to postgis database, run v.in.ogr and the command
consistently warned about a different projection:
In postgresql+postgis server (see the 4326 SRID?):
geoprueba=# select * from geometry_columns where f_table_name='cntry98';
f_table_catalog | f_table_schema | f_table_name | f_geometry_column |
coord_dimension | srid | type | attrelid | varattnum | stats
                 | public | cntry98 | the_geom |
              2 | 4326 | MULTIPOLYGON | | |
In local machine, grass 6.1:
dsn="PG:host=escaton dbname=geoprueba user=postgres" layer=cntry98
output=test1 type=point
comparing "meters"
to "unit"
to "units"
to "meters"
       datum: nad27
       nadgrids: conus
       proj: utm
       ellps: clark66
       es: 0.0067686580
       f: 294.9786982000
       zone: 13
       input data set.
Outputs from g.region and ogrinfo is the same as yours. Investigating
command flow in the source code, I can see in file
grass6/vector/v.in.ogr/main.c, lines 244+ ..
/* Open OGR DSN */
Ogr_ds = OGROpen( dsn_opt->answer, FALSE, NULL );
for ( i = 0; i < navailable_layers; i++ ) {
  Ogr_layer = OGR_DS_GetLayer( Ogr_ds, i );
  Ogr_featuredefn = OGR_L_GetLayerDefn( Ogr_layer );
  available_layer_names[i] = G_store ( (char *)OGR_FD_GetName(
Ogr_featuredefn ) );
Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer);
  &proj_units, Ogr_projection, 1) < 0 )
where Ogr_projection becomes a NULL pointer before calling
GPJ_osr_to_grass(). It seems to be the correct behaviour. Then, in
file grass6/lib/proj/convert.c, lines 227+ ...
                     int interactive)
    struct Key_Value *temp_projinfo;
    char *pszProj4 = NULL, *pszRemaining;
    char *pszProj = NULL;
    if( hSRS == NULL )
        goto default_to_xy;
  default_to_xy:
    if( cellhd != NULL )
        cellhd->proj = PROJECTION_XY;
        cellhd->zone = 0;
    return 1;
So, when receiving a NULL hSRS (the Ogr_projection value), the
function GPJ_osr_to_grass() automatically assume LatLon and exit, and
the string message about OSRExportToProj4() shouldn't appear at all as
the hSRS==NULL is the very first thing checked.
What's happening here? No idea, but it seems to be an issue in your
GRASS install, not in code in CVS. Sorry.
comparing "meters"
to "unit"
to "units"
to "meters"
comparing "(null)"
to "ll"
Segmentation fault
Yes, standard behaviour when using a NULL value in strcmp() function
(file key_value1.c, line 107). The question is, why do we get a null
for "key" value? The "key" parameter is always assigned to a static
string, except in the following files:
general/g.setproj/get_stp.c, lib/g3d/g3dkeys.c and lib/gis/get_projname.c.
It can't be in the first one: calling G_find_key_value(answer, ...) is
preceded by a strcmp(answer, ...) without producing segfault. The same
happens for the third one: strcmp(answer, ...) doesn't segfault, then
answer is not null. And no use of g3d code, so second file is also
descarted.
Again, I'm afraid the error is attached to your install. I can't
reproduce your results from my fresh GRASS 6.1 cvs install (from
yesterday) using your own data.
Sorry, but I quit. Regards,
M.
Hello marcos,
On Fri, 24 Mar 2006 19:56:37 +0100 "marcos boullón magán"
Hello Stephan,
> comparing "meters"
> to "unit"
> to "units"
> to "meters"
?! but why do I have this in my output?
f_table_name='cntry98'; f_table_catalog | f_table_schema |
f_table_name | f_geometry_column | coord_dimension | srid |
| public | cntry98 | the_geom | 2 | 4326 |
MULTIPOLYGON | | |
Exactly. This is what it should state.
comparing "meters"
to "unit"
to "units"
to "meters"
location.
       datum: nad27
       nadgrids: conus
       proj: utm
       ellps: clark66
       es: 0.0067686580
       f: 294.9786982000
       zone: 13
only one odditiy here. AFAIK GRASS was known to figure out the correct
data.projection. In your case this is obviosly not the case since it
states unreferenced/unknown instead of LatLon which should be correct.
e.g.
proj: ll
for the used dataset.
/* Open OGR DSN */
**projinfo, struct Key_Value **projunits, OGRSpatialReferenceH hSRS,
                     int interactive)
    if( hSRS == NULL )
        goto default_to_xy;
  default_to_xy:
        cellhd->zone = 0;
    return 1;
> comparing "meters"
> to "unit"
> to "units"
> to "meters"
> comparing "(null)"
> to "ll"
> Segmentation fault
descarted.
no problem at all. I have learned a lot in this thread, but acctually
it did not solve my problem.
I am going to investigate the whole software chain starting from proj,
geos, gdal, pg, oci, grass
Thanks for your help marcos.
Stephan
