Trying to run v.reclass.pg on the command line with
v.reclass.pg -s sql=recl.sql input=world2 output=test type=area
and recl.sql containing a simple statement like:
select distinct grass_id
from categories
where valeur > 55
I get the following error message and a segmentation fault :
PQgetvalue: ERROR! field number 1 is out of range 0..0
Can someone tell me what this means ?
Moritz
subject 'unsubscribe grass5'
I think the problem is that sql with distinct clause
differs. I would try select distinct on grass_id
grass_id from .. so on. syntacsys changed in postgres
7.0 with this command.
--alex
from categories
where valeur > 55
fault :
0..0
Moritz
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year! http://personal.mail.yahoo.com/
