[GRASS5] Why can't I update table in d.what.vect?
I am trying to enhance the Spearfish dataset with attribute values to use in a class.
I divided the stream vector into its component segements and made a attribute table for streams with an entry for each stream segment. It is linked by a corresponding cat value key field. It looks fine in all ways of checking how this is linked. I’d like to put values in the table.
I can use v.to.db to put in the lengths of each segment, I can use Open Office to manually enter values for each segment, I can use the new v.db.updatecol script to put values in the attribute table. But if I try to do it with d.what.vect or v.digit, I get the following error
Cannot update table:
DBMI_DBF driver error:
SQL parser error in statement:
update streams set LABEL = ‘no name’,
ORDER = 0, LENGTH = 3640.424000, name
= ‘Miller Creek’ where cat = 26
Error in db_execute_immediate()
After I was unable to update label, I made another column “name” using v.db.addcolumn. Again no problem, but I still can’t update it using d.what.vect. I’ve checked the file permissions and they are fine. I’m working in the same (PERMANENT) mapset as the file.
On the other hand, I also added extra columns to archsites and roads and CAN update their tables via d.what.vect.
Any idea what’s wrong here?
Michael
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
