Markus,
Here is a quick fix for the indicated problem
I changed src/display/devices/XDRIVER/XDRIVER24/Panel.c
so that if any part of the window was off screen during
an image capture (popup, menu) the window is moved such that
the entire window is on screen.
try it using d.zoom
put part of the window off screen to each side (top, bottom,..)
I don't like this as a long term solution.
I would prefer popups to be real popups.
To see what my changes are diff Panel.c with the new Panel.c
Unfortunately the sleep(1) was necessary to give XDRIVER24 time to do
its stuff. I hope that moving from file/fifo's to sockets help that,
so that nasty line can be dropped.
C.
E-Mail: candrsn@mindspring.com
Flying Monkeys Usually Mean Trouble.
(attachments)
Panel.c (5.46 KB)
On Tue, May 23, 2000 at 12:22:48AM -0400, Carl Anderson wrote:
Markus,
try it using d.zoom
Carl,
it is working perfectly! Thanks, this will prevent many
users from problems.
Did you find time to look for that? I am just interested
as the windows port (by John) requires such sockets.
Maybe he or someone else could assist?
Many thank for the bugfix,
best wishes
subject 'unsubscribe grass5'
I finally got Cygwin and GCC2.95.2 up and running today. I have some
sample
code but I want to try it out on Win32 before passing it on. Socket
implementations have issues and sockets is a big change that needs
thorough
testing before acceptance.
Did you know that GTK has been ported to Win32 and can generate windows
without needing X. After getting sockets up and running someone could
create
a g[0-9] driver. This may overcomplicate or uncomplicate GRASS
monitors.
GTK/GLIB works with all the major players
Linux/BSD/SUN/SGI/HP/AIX/Win32/WinNT/Ultrix/...
So if it and X were supported by GRASS It could help portability.
I AM NOT SUGGESTING DROPPING X Support only adding a driver to allow
our Win32 friends to not have to add external software (X) to use GRASS.
my 2 cents.
C.
Date: Sun, 01:00:00 +0000 (GMT)
sample code but I want to try it out on Win32 before passing it on. Socket
thorough testing before acceptance.
Maybe John can test as well on his WIN-Port.
create a g[0-9] driver. This may overcomplicate or uncomplicate GRASS
monitors.
Wow, sounds very good. This might simplify the install procedure
on WIN systems.
I agree. As both drivers can co-exist it should not be a problem.
Concerning all:
The branching should be started. I fear I need some assistance to
avoid problems. As GRASS 5 is currently working pretty good (of
course bugs exist), I may start the next days. Or is branching
as trivial as tagging? Two version tags are already applied.
So I will read again the CVS book...
Best wishes
