hi maciek, dear grassers,
i followed the steps proposed by Maciek.
for information about region and resolution settings i attached the v.info and r.info-output from the different steps.
everything seems to work, but not the last step with r.proj.
grass60 is creating a raster-map by r.proj.
this raster-map has the right region, but no content (see r.info below: Range of data: min = nan max = nan)
is there maybe a problem with the proj-library?
thanks in advance
greetings
helli
<Helmut,
<I gues your problem is that you need to set up the region in BOTH inout
<and output location so it covered the extent of raster data you need to
<reproject. This can be easily achieved like this:
<IN INPUT LOACTION
<1 set up the region
<2 v.in.region type=line output=the_region
v.info from step 2:
v.info map=cregion layer=1
| Layer: cregion Organization: |
| Mapset: imagedate Source Date: |
| Database: //home/helli/grassdata |
| Title: |
| Map Scale: 1:1 |
| Map format: native |
| Type of Map: Vector (level: 2) |
| Number of points: 0 Number of areas: 0 |
| Number of lines: 1 Number of islands: 0 |
| Number of boundaries: 0 Number of faces: 0 |
| Number of centroids: 0 Number of kernels: 0 |
| Map is 3D: 0 |
| Number of dblinks: 0 |
| Projection: Transverse Mercator (zone 0) |
| N: 5321295.600 S: 5318948.400 |
| E: 4563992.800 W: 4561644.000 |
| B: 0.000 T: 0.000 |
| Digitize threshold: 0.00000 |
| Comments: |
r.info from the raster of the input-location:
r.info map=comp
| Layer: comp Date: Mon Feb 6 11:01:08 2006 |
| Mapset: imagedate Login of Creator: helli |
| DataBase: //home/helli/grassdata |
| Title: ( comp ) |
| Type of Map: raster Number of Categories: 32767 |
| Data Type: CELL |
| Rows: 2347 |
| Columns: 2349 |
| Total Cells: 5513103 |
| N: 5321295.6 S: 5318948.4 Res: 1.00008522 |
| E: 4563992.8 W: 4561644 Res: 0.99991486 |
| Range of data: min = 0 max = 32767 |
| Data Source: |
| Data Description: |
| generated by r.composite |
<IN OUTPUT LOCATION
<3 v.proj the "the_region" you created in step 2
<4 g.region vect=the_region
<5 r.proj
v.info from step 3
v.info map=cregionsbg layer=1
| Layer: cregionsbg Organization: |
| Mapset: images Source Date: |
| Title: |
| Map Scale: 1:1 |
| Map is 3D: 0 |
| N: 5355698.416 S: 5353360.038 |
| E: 8608139.963 W: 8605864.833 |
| B: 0.000 T: 0.000 |
| Comments: |
r.info from the raster of the output-location:
r.info map=so00641compbay
| Layer: so00641compbay Date: Mon Feb 6 11:20:28 2006 |
| Mapset: images Login of Creator: helli |
| Title: ( so00641compbay ) |
| Type of Map: raster Number of Categories: 255 |
| Data Type: FCELL |
| Rows: 2340 |
| Columns: 2276 |
| Total Cells: 5325840 |
| N: 5355698.98489831 S: 5353359.0418025 Res: 0.99997568 |
| E: 8608140.67246773 W: 8605864.66151311 Res: 1.00000481 |
| Range of data: min = nan max = nan |
| Data Source: |
| Data Description: |
| generated by r.proj |
<Maciek>
GRASS 6.0.1 (2005)
Maciek Sieczka <werchowyna@epf.pl> schrieb am 03.02.06 17:57:19:
Helmut,
IN INPUT LOACTION
1 set up the region
IN OUTPUT LOCATION
5 r.proj
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
______________________________________________________________
Verschicken Sie romantische, coole und witzige Bilder per SMS!
Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193
