[GRASSLIST:1071] Grass and mapserver question
I use GRASS 5.0.2 and Mapserver 3.6.6, and I am trying to make a connection between GRASS and Mapserver. I downloaded the DEMO 1 from
http://grass.itc.it/start.html
and everything was fine except the soils map.
Thus I tried to write a very small map file:
name grsmap
extent 590000 4914000 609000 4928000
size 500 500
shapepath "/var/www/html/spearfish"
layer
  name "grsmap"
  data "elevation.tif"
  status default
  type raster
end
end
and it was ok, but after I changed 2 places:
  shapepath "/data/grassdata/spearfish"
  data "PERMANENT/cellhs/soils"
and ran mapserv, it showed
msDrawRaster():Image handliing error. Unrecognized or unsupported image format.
Is it because the data in my grass database is not 8 bit format? if so, how could I fix this?
Thank you...
Lingyen
On Fri, Aug 29, 2003 at 10:09:42AM -0400, Ling-Yen Liao wrote:
how could I fix this? Thank you...
See at bottom of
the new Troubleshooting entry (use r.rescale).
Markus Neteler
Hello.
First you have to convert the vector map into a shape file:
#vector layer in SHAPE:
#v.out.shape map=soils type=area pref=soils cats=string
DATA /path_to_htmldocs/spearfish/soils
or, if you want to display a raster map:
GRASS GIS raster map directly from location (8bit only):
LAYER
  STATUS ON
  DATA "/path_to_grassdata/spearfish/PERMANENT/cellhd/soils"
END
And also be carefully with the file's permisions.
Sorry for my poor english.
Markus Neteler(neteler@itc.it)@08.09.2003 18:38:19 +0000:
> Hi,
See at bottom of
Markus Neteler
Vim make me a joke :slight_smile:
Jorge del Pozo(jorpoz@pesquera.tel.uva.es)@09.09.2003 08:51:13 +0000:
Hello.
LAYER
    NAME soils
    TYPE RASTER
  STATUS ON
END
