[GRASSLIST:1205] problem installing GRASS5.0beta in linux RH6.0
Hi:
I am trying to install GRASS5.0beta in my RH6.0 box (Intel version) but
I'm getting the
following error message when I try the "make install':
if [ ! -d /usr/local/grass-5.0b ]; then mkdir /usr/local/grass-5.0b ; fi
if [ ! -d src/CMD/next_step ]; then mkdir src/CMD/next_step ; fi
env UNIX_BIN=/usr/local/bin SRC=`pwd` GISBASE=/usr/local/grass-5.0b
MACHINENAME=`uname -n` /bin/sh src/CMD/generic/CREATE_GMAKE.sh
mkdir -p -m 755 /usr/local/grass-5.0b
/bin/sh `pwd`/src/CMD/generic/is64bit.sh
env GRASSSRC=`pwd`/src GMAKE=`pwd`/src/CMD/gmake5.0 /bin/sh
src/CMD/generic/GISGEN.sh
SRC=/home/eramos/temp/grass5.0beta/src
CMD=/home/eramos/temp/grass5.0beta/src/CMD
HEADER=head
ARCH=i686-linux-elf
GISGEN Fri Dec 1 10:03:59 CST 2000
GISBASE = /usr/local/grass-5.0b
SRC = /home/eramos/temp/grass5.0beta/src
CMD = /home/eramos/temp/grass5.0beta/src/CMD
HEADER = head
ARCH = i686-linux-elf
first step: src/display/d.3d
GISGEN: src/display/d.3d - Fri Dec 1 10:03:59 CST 2000
/home/eramos/temp/grass5.0beta/src/display/d.3d
  make -f OBJ.i686-linux-elf/make.rules
make[1]: Entering directory
`/home/eramos/temp/grass5.0beta/src/display/d.3d'
rm -f OBJ.i686-linux-elf/get_inputs.o
gcc -g -O2 -I/home/eramos/temp/grass5.0beta/src/include -c
get_inputs.c
make[1]: Leaving directory
GISGEN failure at STEP: src/display/d.3d
Any ideas??? recommendations???
-Elio Ramos
  eramos@cuhwww.upr.clu.edu
  University of Puerto Rico - Humacao
Hi Elio
On Fri, Dec 01, 2000 at 11:01:31AM -0500, Elio Ramos wrote:
Hi:
I'm getting the
HEADER=head
ARCH=i686-linux-elf
HEADER = head
get_inputs.c
Which GRASS 5 beta do you use?
And: please send the *full* error message. You may send it personally
to me. To get it again enter:
gmake5 src/display/d.3d
Kind regards
Markus Neteler
