[GRASSLIST:134] s.in ascii problem
Dear grass list
I am usin GRASS5.0
I am trying to import 3 dimensional data with command
s.in.ascii site=salinity input=sal.asc d=3
and the data looks:
40:55E 67:28N -1 #1 %31.147
40:55E 67:28N -3 #2 %31.147
40:55E 67:28N -7 #3 %31.147
40:55E 67:28N -12 #4 %31.147
40:55E 67:28N -17 #5 %31.147
40:55E 67:28N -22 #6 %31.147
41:01E 67:28N -1 #7 %31.138
41:01E 67:28N -3 #8 %31.138
41:01E 67:28N -7 #9 %31.138
41:01E 67:28N -12 #10 %31.138
when I try to display data, it gives the error
ERROR: G_site_new_struct: invalid # dims or fields
I tryed also so that the 3dr dimension was only -1 ( surface points of the sea area), but with te same error.
It worked at least earlier with negative values as the 3rd dimension. I trye also fith different field separators.
I can' understund whta is the problem.
Best regards
Seppo Kaitala
