[GRASSLIST:1647] Using atan function
hello
I want to make sure that using atan function.
I have two maps containing sin and cosine values in radian.
Using atan function in r.mapcalc is correct in this way:
r.mapcalc dene='atan(map_cosine*180/3.14,map_sine*180/3.14)' ?
kind regards
Ahmet Temiz
General Directory of Disaster Affairs
Ankara TURKEY
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
sine and cosine aren't angles, so they aren't "in radians" (or
anything else).
If you want the result in degrees:
  r.mapcalc 'dene=atan(map_cosine,map_sine)'
For radians:
  r.mapcalc 'dene=atan(map_cosine,map_sine)*3.14/180'
There is no point scaling the sine/cosine values, although it won't
make any difference as atan(y*k,x*k) == atan(y,x) for all k > 0.
[Aside: does r.mapcalc need a pi() function? Or deg2rad()/rad2deg()
functions? Or, for that matter, anything else?]
Yes, that would be nice. So we all had the same pi, and the
other proposed functions were also convenient.
