Hi list:
[this is my third attempt to post this solution to the GRASSLIST, as there's something wrong with @baylor.edu--if someone on GRASS5 could forward this to the GRASSLIST, I'd appreciate it. I wrote to Art and George directly with the solution]
If a Mac OS X (pb and 1.0) user tries to fire up GRASS, the following error occurs:
Error opening terminal: vt100
The solution (kudos to strobe) is to cd to the directory where your spearfish directory is (i.e. if its found in /opt/spearfish, cd /opt) and enter the following:
grass5 spearfish/PERMANENT
Voila!
Take care,
Andy
---------------------------------------- If you want to unsubscribe from GRASS Development Team mailing list write to:
subject 'unsubscribe grass5'
Hi Andy
andy agena wrote:
Hi list:
error occurs:
Voila!
Although this is a workaround, it does not actually solve the problem.
Is there anyone with insight as to what is causing the problem? It would
be nice to solve this problem if it is a Grass problem.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
> error occurs:
[snip]
My money is on it being curses/termcap/terminfo, e.g. no terminfo
database installed, or only a minimal one (although if it doesn't have
"vt100", it's very minimal).
