[GRASSLIST:1932] digitilize shapes
I have a problem with the digitalization of
shape files in Grass 5.7.
I registered a shape and I can correctly display
it. I would like to modify the shape and save
the result as shape.
I tried to digit it, with v.digit, but the
output display say:
"Warning: shape file format can not be update.
Cannot open old vector ***.shp at PERMANENT on
level 2"
I can convert the shape file in grass vector
format and then digitilize it but I cannot
convert the vector in a shape file at the end
because the command v.out.shape is not present
in Grass 5.7.
Can someone help me?
Thank you
Leonardo Lami
output display say:
level 2"
in Grass 5.7.
v.out.ogr
Radim
