Can anyone tell me how to change LD_LIBRARY_PATH to DYLD_LIBRARY_PATH globally? Even though the configuration file says:
LD_LIBRARY_PATH_VAR="DYLD_LIBRARY_PATH"
under the definition for Darwin-*, I still get the following:
cd OBJ.powerpc-apple-darwin7.0.0; LD_LIBRARY_PATH=:/usr/local/src/grass57_exp_2003_11_22/dist.powerpc-apple-darwin7.0.0/lib ./test
ERROR in read/write portable short, byte_order = 0
Written: -32768
Read : 0
Written: -12345
Read : -57
Written: 12345
Read : 57
Written: 32767
Read : -1
make[3]: *** [OBJ.powerpc-apple-darwin7.0.0/test] Error 1
make[2]: *** [subdirs] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
notice that its NOT using DYLD_LIBRARY_PATH as it is supposed to.
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
