[GRASSLIST:2029] How to enter coordinates on the DEFINE REGION screen
I have searched far and wide and not found any information providing help as to how to enter coordinates in the define region screen. One would think someone somewhere would need help with this basic operation.
By trial and error I managed to figure out how to enter degrees. DD:MM:SS.
Sounds simple, but there are a multitude of ways to describe degrees so luckily I didn't waste too much time on that.
However I am currently struggling with UTM coordinates. How do you enter them on the DEFINE REGION (i.e. start up with a new location) screen.
One problem regardless of the actual syntax: half the time I enter UTM coordinates and the GRASS 5.3 program tells me that the north edge value must be larger than the south edge. Well in my world the UTM values for the south edge are smaller absolute value-wise than for the north edge. And it won't allow me to enter things like "10S544490mE". Help?
So why should I care that GRASS has it's own inverted number system for a region? I just want to define a raster image as being in UTM space.
thank you
    rad
__________________________________________________________________
McAfee VirusScan Online from the Netscape Network.
Comprehensive protection for your entire computer. Get your free trial today!
http://channels.netscape.com/ns/computing/mcafee/index.jsp?promo=393397
Get AOL Instant Messenger 5.1 free of charge. Download Now!
http://aim.aol.com/aimnew/Aim/register.adp?promo=380455
operation.
DD:MM:SS. Sounds simple, but there are a multitude of ways to describe
screen.
For everything except lat-lon, coordinates are just decimals (integers
or decimal fractions). For lat-lon, you can use either DD:MM:SS[NSEW]
or decimals.
or decimals.
Hello list,
I want to create a new Location, as there is in GRASS manual, I had started by xy location, and define my region by decimals. but when I use g.region -pm it says:
PROJ_INFO file not found for location mtest3.
…I have too much problem for creating new location and import maps to it,
is it possible that I send you all my attempts step by step? and you correct it? maybe it is useful for others.
Best Regards
Maliheh
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing
or decimals.
Hello list,
Best Regards
Maliheh
Do you Yahoo!?
> or decimals.
use g.region -pm it says: PROJ_INFO file not found for location
mtest3.
That appears to be a bug in 5.3. It doesn't happen (for me) with
5.0.3, or with locations which have a defined projection. However, in
spite of that message, g.region appears to work OK.
Hello list,
Sorry but I have a primary problem yet!
As I wrote it before, I know that at first we should create a xy location, and import a raster map, then transform it to a UTM location, so before use of i.target we should create another location, with UTM coordinate system. Am I right?
If yes, in this step I should create a new location:
DEFINE THE DEFAULT REGION
====== DEFAULT REGION ====
| NORTH EDGE: 35.73581 |
WEST EDGE| | EAST EDGE
51.40387 | | 51.43422
| SOUTH EDGE: 35.71539 |
PROJECTION: 1 (UTM) ZONE: 0
GRID RESOLUTION
East-West: 0.0002042
North-South: 0.0003035
Then it asks me:
à Do you wish to specify a geodetic datum for this location?(y/n) [y]
but my map is a jpg file that I don’t know more detail about it, so I don’t know what should I write for this and next question:
à Please specify ellipsoid name
Enter ‘list’ for the list of available ellipsoids
Hit RETURN to cancel request
As a result at the end of creating new location, GRASS says:
à LOCATION <mtest3_1> created
But the PROJECTION information files were not created!
You must run g.setproj successfully before projection software will work
Would you please help me, I want to create my own location, and work on my maps?
Your response will be so appreciated.
Best Regards
Maliheh
Do you Yahoo!?
At 11:18 PM 12/21/2003, you wrote:
Hello list,
That depends on what projection your raster map is in. If your raster map is UTM then all you need to do is import it into your location. Is your raster map geo-referenced (does it have a projection)? Do you know what that projection is? What type of raster map are you trying to import - is it an image?
How many map layers do you have? Are they all in the same projection? If you only have one layer, or if all of your map layers are in the same projection, you can ignore datum and ellipsoid.
R
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
Hello list,
system. Am I right?
it an image?
yes it is an image that I’v scanned it, and just I know it’s coordinates, and I want to geo-reference and use it with GRASS, now would you please help me again?
Thanks a lot
Do you Yahoo!?
Yahoo! Photos - Get your photo on the big screen in Times Square
Hello dear GRASS list,
I want to describe my problem from the beginning for you, I wish you can and you want to help me and also it can be helpful for others.
I want to create a new location for my region; I don’t have any digital map that match my need, I have just a paper map and a GPS receiver, with use of gpsdrive I noted coordinates of four points on my map. Gpsdrive shows the coordinates like this:
Latitude: 35.73581 Longitude: 51.40387
And also I know that my region is between 34:52N , 34:21N and 50:10E , 53:10E; and my map scale is 1/12000 and the resolution of scanned map is 100dpi.
Now start the grass5.7 for creation new location:
a. LOCATION: test________ (enter list for a list of locations)
MAPSET: root__________ (or mapsets within a location)
DATABASE: /usr/local/src/GIS/grassdata
b. LOCATION - doesn’t exist
Would you like to create location ? (y/n) y
c. To create a new LOCATION, you will need the following information:
  1. The coordinate system for the database
x, y (for imagery and other unreferenced data)
Latitude-Longitude
UTM
Other Projection
  1. The zone for the UTM database
and all the necessary parameters for projections other than
Latitude-Longitude, x, y, and UTM
  1. The coordinates of the area to become the default region
And the grid resolution of this region
  1. A short, one-line description or title for the location
Do you have all this information for location ? (y/n) y
d. Please specify the coordinate system for location
A x, y
B Latitude - Longitude
C UTM
D Other Projection
RETURN to cancel
A
x, y coordinate system? (y/n) [y] y
e. Please enter a one line description for location
Create a new Location
Ok? (y/n) [y] y
f. DEFINE THE DEFAULT REGION
| NORTH EDGE: 36 |
WEST EDGE | | EAST EDGE
50 | | 53
| SOUTH EDGE: 34 |
PROJECTION: 0 (x, y) ZONE: 0
GRID RESOLUTION
East-West: 0.03
North-South: 0.02
g. projection: 0 (x,y)
zone: 0
north: 36
south: 34
east: 53
west: 50
e-w res: 0.02 (Changed to conform to grid)
n-s res: 0.03 (Changed to conform to grid)
total rows: 100
total cols: 100
total cells: 10000
Do you accept this region? (y/n) [n] > y
LOCATION has been created!
I know that in some steps specially those with red highlight, I’ve done something wrong, but I don’t know how I should correct it. Because when I use g.region –pm, it says: PROJ_INFO file not found for location “test”.
Therefore in other steps like use of r.in.gdal I have problems too.
Would you please help me, it’s so important for me. Your response will be sooooooooo appreciated, and I wish for you the best.
Regards
Maliheh
Do you Yahoo!?
Find out what made the Top Yahoo! Searches of 2003
Maliheh,
I'm not an expert here but, if you know the lat/long
of your region, why are you creating a XY region and
not a lat/long?
Maybee that's it, but once again, I'm not an expert...
Daniel
b. LOCATION <test> - doesn't exist
Would you like to create location <test>? (y/n) y
data)
        Latitude-Longitude
        UTM
        Other Projection
2. The zone for the UTM database
other than
3. The coordinates of the area to become the default
region
4. A short, one-line description or title for the
location
<test>? (y/n) y
location <test>
A x, y
C UTM
D Other Projection
RETURN to cancel
> A
location <test>
Ok? (y/n) [y] y
                       | NORTH EDGE: 36
WEST EDGE |
       | EAST EDGE
50 |
             | 53
                       | SOUTH EDGE: 34
  ZONE: 0
                             GRID RESOLUTION
East-West: 0.03
North-South: 0.02
zone: 0
north: 36
south: 34
east: 53
west: 50
total rows: 100
total cols: 100
total cells: 10000
LOCATION <test> has been created!
know
=== message truncated ===
Do you Yahoo!?
http://search.yahoo.com/top2003
Thank you Daniel,
I checked it, but my problem didn’t solved :frowning:
My another problem is When I use r.in.gdal to import a jpg file, it says:
r.in.gdal input=teh10.jpg output=test
PROJ_INFO file not found for location mtest7
PROJ_UNITS file not found for location mtest7
100%
CREATING SUPPORT FILES FOR test.red
SETTING GREY COLOR TABLE FOR test.red (8bit, full range)
100%
CREATING SUPPORT FILES FOR test.green
SETTING GREY COLOR TABLE FOR test.green (8bit, full range)
100%
CREATING SUPPORT FILES FOR test.blue
SETTING GREY COLOR TABLE FOR test.blue (8bit, full range)
so I have 3 raster map in my location, but I can’t see any of them by use of d.rast or d.rgb,
Would you please tell me my wrong?
Daniel Victoria daniel_victoria@yahoo.com wrote:
Maliheh,
I’m not an expert here but, if you know the lat/long
not a lat/long?
Maybee that’s it, but once again, I’m not an expert…
Daniel
— Maliheh
Do you Yahoo!?
Maliheh,
Since your jpeg is not georefereced, it does not fall
in the region you defined. To see the images, first
you'll have to set the region to that image. The
comand is
g.region rast=test
then you can see you images with d.rast or if you'd
like to see the color composite you can use d.rgb
After that you will have to georeference the images so
it will fall in you current region. To do that you use
the command i.points (or something similar, cant
remember now and I'm away from my computer with grass)
Daniel
Thank you Daniel,
I checked it, but my problem didn't solved :frowning:
100%
range)
100%
range)
100%
range)
so I have 3 raster map in my location, but I can't
Daniel Victoria <daniel_victoria@yahoo.com> wrote:
Maliheh,
not a lat/long?
expert...
Daniel
for
also
my
100dpi.
> b. LOCATION - doesn't exist
> data)
> Latitude-Longitude
> UTM
> Other Projection
> other than
default
> region
> location
> ? (y/n) y
> location
> A x, y
> C UTM
> D Other Projection
> RETURN to cancel
> > A
> location
> Ok? (y/n) [y] y
> | NORTH EDGE: 36
> WEST EDGE |
> | EAST EDGE
> 50 |
> | 53
> | SOUTH EDGE: 34
Do you Yahoo!?
Hey there Maliheh, I am not sure if you have finished this project yet, but this
might help. You have imported the jpg correctly into the xy, so that is good.
You now need to use the imagery commands. First you need to use i.group to
make an imagery group of your test.r test.b and test.g.
Then you need to set a target location using i.target. This will be the
georeferenced location that you will project your rasters into. In your case
probably a lat-long location. You will need to create this. Exit your
location, create a new lat-long location, exit that, and then come back to your
xy location, and set the target location using i.target.
Then you have to use i.points to set the control points. This should be self
explanatory once you use it. After i.points, use i.rectify. First order
transformation should be fine for what you need. After that finishes, exit the
xy location, go into the lat-long location, and the images should be there.
Good luck
ian
On Wed, Dec 31, 2003 at 04:15:00AM -0800, Daniel Victoria wrote:
Maliheh,
comand is
g.region rast=test
Most unreferenced maps are imported with *negative* XY coordinates
when using r.in.gdal. This behaviour should be discussed
and probably changed. IMHO positive XY coordinates should be
written except for AVHRR (as far as I remember, maybe also SAR).
Markus Neteler
Are both the X and Y co-ordinates negative? If so it doesn't seem to make
sense. It would make sense to me if only the Y co-ordinates were negative,
as then the absolute y co-ordinate of the centre of each pixel would be
the same as its row number (in the conventional way of numbering pixels in
image processing). This is maybe more familiar to people like me who
currently do most image processing in MATLAB.
But I don't really know how this works in practice and if it's hard to get
your head around while actually doing image processing in GRASS. If you
were just temporarily importing into the XY location before rectifying
then I don't see that the XY co-ordinate system would make much difference
at all.
Probably there is another disadvantage that I have missed?
Paul
Yes, but for some formats I have already fixed it and changed to
positive XY coordinates. The r.in.gdal code needs a cleanup IMHO,
at least it is fairly complex now to read.
For me simply positive coordinates were fine (no MATLAB user).
at all.
As far as I understand the problem it's a matter of convention.
So changing the behaviour should be ok (and avoid the many user mails
here where they import and don't find the image later).
Maybe Frank has a comment for us?
Hello Dear list,
At first I should say thank you for your responses. Now I have a better idea about my work.
Till now I know that we have to import our scanned map in a xy location, then by use of i.group, i.target and i.points, transform it to a second location (lat/long in my case).
But I don’t understand how we should specify our map scale. I read the manual about grid resolution:
Resolution: 100*100 dots per inch
100 dpi = 100 rows / 2.54 cm = 39.37 rows/cm
scale of the map: 1:12000
Distance in nature / scanned rows per cm = 12,000 cm / 39.37 rows
= 304.8 cm/row = 3.048 m/row GRID RESOLUTION
but when I enter this value GRASS shows me:
projection: 0 (x,y)
zone: 0
north: 36
south: 35
east: 52
west: 51
e-w res: 1 (Changed to conform to grid)
n-s res: 1 (Changed to conform to grid)
total rows: 1
total cols: 1
total cells: 1
Now would you please tell me my wrong, again ?
Do you Yahoo!?
But I don't understand how we should specify our map scale. I read the
  projection: 0 (x,y)
  zone: 0
  north: 36
  south: 35
  east: 52
  west: 51
  total rows: 1
  total cols: 1
  total cells: 1
The boundary (North/South/East/West) coordinates need to have the same
units as the resolution. E.g. if you are specifying the resolution in
metres, then the boundary coordinates must also be in metres (and not
in e.g. degrees).
For an X/Y location, it doesn't matter exactly which units you use, so
long as they are consistent. But you appear to be specifying a
resolution of approximately 3 units for a map which is one unit high
(36 - 35) by one unit wide (52 - 51).
BTW, for a Lat/Lon location, you need to use degrees, while projected
(e.g. UTM) locations typically need to use either metres or feet.
