[GRASSLIST:221] Importing Tiger Data with v.in.ogr
I would like to create vector maps from Tiger Data. Some of these are lines (Roads, Streams, ...) and some are areas (Census Block, Zip Codes, ...) I have tried to use v.in. ogr but I seem to be missing something in the process. What I get is a map of all of the vector lines, but I am not seeing how to differentiate specific attributes. Is there a tutorial or explanation on using v.in.ogr with Tiger?
Brian
You have to extract the pieces/vectors that you want before you load it
with v.in.ogr. The best source of information that I have found is a
very old www.udel.edu source, complete with examples.
Here is the link:
http://www.udel.edu/johnmack/frec682/682proj3.html
Hope it helps.
Ed Davison
Sr. Systems Analyst
McCombs School of Business
512-232-6620 voice
Brian,
the manual page of v.in.ogr explains TIGER import (it's a bit
special) - doesn't work?
http://grass.itc.it/grass60/manuals/html60_user/v.in.ogr.html
http://grass.itc.it/grass61/manuals/html61_user/v.in.ogr.html
In response to all.
I am trying to import raw Tiger Data. Using awk to extract the significant features is what I will have to do. It is what I did when I was a student of John MacKenzie's at Delaware in the mid 90's (so be careful of the "very old" adjective.) His instructions were what I used when using the old v.in.tig in Grass 4 and 5. I had assumed that v.in.ogr had eliminated this approach, and thus I was hoping to find out if it had. The documentation v.in.ogr is excellent for importing shape files, but it seem very limited (in my opinion) when addressing raw Tiger Data. Thanks for all of your help.
Here is the link:
Hope it helps.
Ed Davison
Sr. Systems Analyst
512-232-6620 voice
J. Brian Adams
Asst. Professor of Computer Science
206 Stager Hall
Franklin & Marshall College
Lancaster, PA 17604-3003
(717) 291-3872
On Fri, Mar 17, 2006 at 09:44:58PM +0100, we recorded a bogon-computron collision of the <neteler@itc.it> flavor, containing:
Brian,
The example command in the man page just shows how to pull in boundaries and
centroids. There are a number of layers in the TIGER data that link to
the POLYID in the centroid records that are not imported by that command.
How would one go about importing these into additional "layers" in the grass
vector model and linking them to the main centroid via the key "POLYID"?
For example, there is a table in the TIGER/Line data called "AreaLandmarks".
If a POLYID has a record in AreaLandmarks then there is additional information
available in the Landmarks table, which is linked to AreaLandmarks via a
key "LAND". So one could find, for example, that POLYID 8921 in TIGER Module
TGR35001 has an associated AreaLandmark record that has LAND of 19, which
points to the Landmarks table to show that this polygon is part of a military
base called Kirtland Air Force Base.
Following the instructions in the v.in.ogr man page and clicking
on the same polygon with d.what.vect tells us only that this polygon is
CENID c4588, is not water, and has the lat/lon POLYLONG : -106416279
POLYLAT : 34975894 without any of the feature codes or landmark names.
Can v.in.ogr be used to import the extra tables AreaLandmarks and Landmarks
into additional layers, and if so what does one have to do to set up the
linkages with v.db.connect so that a click on the polygon with d.what.vect
shows all the information two paragraphs above instead of only that in the
last paragraph?
To get that sort of information out of TIGER/Line files when I needed it, I
just had to hack on the python script "tigerpoly.py" that comes with
gdal in the pymod/samples directory --- that program does little more than what
the example in v.in.ogr's man page does, but it wasn't that hard to extend
it: I wound up generating a monolithic dbf file with the combined information
in PIP, AreaLandmarks and Landmarks for every record, and dumped a shapefile,
which I then read into GRASS.
I'd love to see how to do it without resorting to python scripting, now that
it is possible to have multiple layers in grass vectors.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
