[GRASSLIST:2248] RE: i.points
It is a good idea to toggle off the points in the "Analyse" option in i.points, you may still see the marked points which appear red on the map; those points will not be counted in calculating the RMS error. I think you have to import those images again and create a new group and subgroup if you want to start anew in the same location. You can chech it out.
best wishes,
uttam.
To: GRASSLIST@baylor.edu
Subject: [GRASSLIST:2216] i.points
Date: Wed, 14 Jan 2004 09:20:59 -0600
How does one delete points in order to just start over? I have already toggled the points off in the analyze section, but they still appear in red on the map. Is there a way to simply b"blow away" the all points and start anew?
Kirk
_________________________________________________________________
NRI’s, Free Money transfer to India. http://server1.msn.co.in/msnleads/citibankrca/citibankrca2.asp?type=hottag Click here.
