[GRASSLIST:2253] Re: m.eigensystem doesn't work ?
On Fri, Jan 16, 2004 at 12:41:57PM +0100, LJunek@t-online.de wrote:
> > Hi,
> > I try to generate the eigensystem for some data and use Grass 5.3cvs.
> > (m.eigensystem was compiled from the current cvs code).
> > Unfortunately nothing happens when I use the command
> > "m.eigensystem" ! There's no error message, the command is not unknown.
> Please post the complete error message.
> Did you run
> gmake5 -i
> gmakelinks5 -i
> within the source code directory of m.eigensystem?
> Markus
I then ran the -i commands, actually there's NO ERROR MESSAGE.
m.eigensystem doesn't ask for an input file, still nothing happens...
Is there another possibility to analyze the content of the 1st, 2nd, 2rd
principal component? I would like to interpret the results of pca.
L
OK, got it. The Gmakefile was wrong.
The change is:
cd src.contrib/CERL/misc/m.eigensystem/
diff -r1.5 Gmakefile
12c12
< $(BIN_INTER)/$(PGM): $(OBJ)
$(BIN_CMD)/$(PGM): $(OBJ)
If you are not compiling GRASS yourself, you may try to
copy WITHIN GRASS:
cp $GISBASE/etc/bin/inter/m.eigensystem GISBASE/etc/bin/cmd/m.eigensystem
Then run
m.eigensystem < inputfile.txt
This should work.
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
