Hello list,
How can we set debug level and debug file in grass57? We tried the environment variables GRASS_DEBUG_LEVEL=9, DEBUG=filename1 GRASS_DEBUG_FILE=filename2, v.digit did not report any debug info to filename.
How can we compile just 1 module again in grass57? Executing make in module dir, compiled just the object files, but not the executable.
TIA,
Sjors
Try using:
g.gisenv set=DEBUG=9
for debug level 9, for example.
Chris
On Jan 18, 2004, at 9:57 AM, Sjors wrote:
Hello list,
TIA,
Sjors
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
On Sunday 18 January 2004 18:02, Christopher Fonnesbeck wrote:
Try using:
Currently the maximum debug level used is 5, AFAIK.
> Hello list,
> filename.
Which module, standard module or your own? Just to run make in the module
directory should be enough if Makefile is written correctly.
Radim
