Kirk,
you are right I modified Biome-BGC of Running et al. . I simplified it a lot because my aim is to calculate the amount of C stocked in a year by forest of a region. So I chose as out put only totalc, vegc, soilc and litterc. I removed the spinup simulation not to weight down the module so the user must have many initialization parameters. Now I'm testing the module to see if it works. If you need more informations just tell me and I will try to answer you.
Bye
Chiara
Da: Kirk R. Wythers <kwythers@umn.edu>
Data: Tue, 20 Jan 2004 13:17:12 -0600
A: "chiara.sboarina@katamail.com" <chiara.sboarina@katamail.com>
Oggetto: Re: BGC GRASS module
Chiara,
I'd be interested to hear more about your module. What was it designed
to do? I assume you are talking about the BGC family of ecosystem
models (Running et al.).
Kirk
On Jan 19, 2004, at 1:55 AM, chiara.sboarina@katamail.com wrote:
Hi Scott,
I succeded to compile the module last week but I haven't tried it yet
because I need to prepare the input maps and data. As soon as I test
it I make you know how it works. My aim is to calculate the amount of
carbon stocked by the forest of the entire province where I work. I'll
keep you up to date.
Bye
Chiara
Kirk R. Wythers tel: 612.625.2261
Dept. of Forest Resources fax: 612.625.5212
University of Minnesota email: kwythers@umn.edu
