Hi all, sorry to be pestering the list lately, every time I think I get it all,
I realize just how big the mountain of information is that I don't understand.
Here's my problem, I downloaded some aster dems from the EOS data gateway. It
comes in HDF-EOS format, and obviously my r.in.gdal (version 1.1.7 I believe)
can not read it (I am running 5.0.0 on mac os 10.2.8). I would like to be able
to import this data into GRASS, however it seems very non intuitive to a mac
user like me (I installed GRASS with the openosx cd). I have read and reread
the mail archives and tutorials, as well as several other web sources, but I
still just don't get how I can do this. It seems to me that I need to update
gdal to 1.1.9 (it looks like it handles hdf 4.x and hdf-eos files), and then I
should be ok, but how do I do this? I have downloaded the binaries from
remotesensing.org. and it is sitting on my desktop staring at me. Now what?
Can I just update gdal without having to recompile grass?
How do I update gdal?
If I need to recompile grass, how do I do that on osx?
Mucho thanks for any help you all might give,
Ian
P.S.
I also downloaded the HDFLook program as an alternative, but again, I have the
unzipped file sitting on my desktop staring at me. If using that program is
easier to explain, feel free to let loose if someone knows how.
Does r.in.gdal use a shared GDAL library (e.g. libgdal.1.1.dylib) or a
static library (e.g. libgdal.a)? If you can't find a likely .dylib
file (in e.g. /sw/lib, /usr/local/lib, /System/Libraries etc), it's
probably using a static library. If you can find a likely .dylib file,
try renaming it; if r.in.gdal stops working, it's using the .dylib
file.
If it's a shared library, you should be able to just replace the
existing library with the new version. If it's a static library, you
need to re-compile GRASS.
See the INSTALL file which is included in the top-level directory of
the GRASS source distribution, and also available at:
http://grass.itc.it/grass5/source/INSTALL
Note: On MacOSX, r.in.gdal requires the use of the --with-gdal
configure switch.
