Not a great week for getting the cvs build to work on my linux machine.
This time it seems to be with r.le:
You have to run:
make mixclean
make mix
(better explained in INSTALL file).
because of directory changes today in 5.7 (which brings r.le to you).
At time you have two files in the same directory, which are
separated now into two directories in CVS to allow for compilation.
You have to run:
make mixclean
make mix
This is certainly not the problem. I have successfully updated and built grass57 from cvs dozens of times, according to the INSTALL file. Something else is wrong here.
C.
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
>>machine.
>You have to run:
>make mixclean
>make mix
This *is* certainly the problem. This is the first time since month
that such a "heavy" chance was submitted. You have a file in that directory
linked from 5.3, which should be there any more.
There is no other way as following these rules:
cd /where/your/grass530/lives/
cvs update -dP
cd /where/your/grass57/lives/
make mixclean #here verify, that grass57/raster/r.le/r.le.setup/polytocell/ does
# not contain any links to 5.3 (the file bmf_to_cll.c should not be there
# any more which is causing the problem on your computer).
cvs update -dP
make mix
configure ...
make
Then it should compile. If not, post the contents (ls) of above
directory.
M.
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
> >>machine.
> >You have to run:
> >make mixclean
> >make mix
cvs update -dP
AFAICT, "make copymix" will fall down in this situation; perhaps that
option should be removed?
Also, this is one of the reasons why using tricks like:
> > >>machine.
> > >You have to run:
> > >make mixclean
> > >make mix
> cvs update -dP
> make mixclean
OBJS = $(subst .c,.o,$(wildcard *.c))
is generally considered to be a bad idea.
GRASS 5.7 is always open for new developers to improve it.
> > >>machine.
BTW, it is not required to compile GRASS 5.7/Linux yourself.
Every saturday (exceptionally also yesterday) a precompiled
GRASS 5.7/Linux binary package is offered here:
