> Binaries OS X are ready.
> You go to:
> http://wwwamb.bologna.enea.it/forgrass/
> and downaload the DMG files.
> Now you can install Grass with double clic
> These are the first release.
LIBRARIES REQUIRED
Install these programs from FINK:
- gdbm
- gd
gdbm and gd don't do anything and are no longer needed for 5.3 and 5.7.
(someone correct me if I'm wrong here..)
gdbm was never actually required for anything; the configure tests
have since been removed (although the 5.7 configure.in does still have
the LOC_MSG_USE(DBM support,USE_DBM) line).
> You go to:
LIBRARIES REQUIRED
- gdbm
- gd
GD is no longer required for 5.3 or, AFAICT, 5.7.
OK. I have delete them from list.
P.S. Try last GDAL 1.2.0 for OSX im my site. HDF support now work using gdalwarp utility for converting HDF format to Geotiff coordinate
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti@bologna.enea.it ||/|/| ENEA prot Web: http://wwwamb.bologna.enea.it/ || | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (res.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
Download GRASS for MAC OS X: http://wwwamb.bologna.enea.it/forgrass/
