[GRASSLIST:2856] Roussilhe Oblique Stereographic
hello
I'm using Grass 5.03
I need to make a mapset in a projection called Roussilhe Projection (alias
Quasi-Stereographic) on the Krassovsky ellipsoid, modified Pulkovo 1942
datum different than those included in libproj but the datum os not an issue
here, I solved it myself
the complete system (ellipsoid, datum and projection) is an old, the most
popular and widely used system in Poland (called "System 1965" ("Uklad 1965"
in Polish))
the issue is the projection only - there is no projection called like it in
Grass
notice: the projection name is my literal translation from Polish; I'm not
sure what is the proper name in English though I have met some sound similar
any ideas how to apply this projection in Grass?
thanks in advance
Maciek Sieczka
in Polish))
Grass
I have:
PROJ_INFO
datum: S-42
towgs84: 33.4,-146.6,-76.3,-0.359,-0.053,0.844,-0.84
proj: tmerc
ellps: krassovsky
a: 6378245.0000000000
es: 0.0066934216
f: 298.3000000000
lat_0: 0.0000000000
lon_0: 18.9583333330
k_0: 0.9999830000
?_0: 237000.0000000000
y_0: -470000.0000000000
DEFAULT_WIND
proj: 99
zone: 0
north: 5648000
south: 4928000
east: 612000
west: -108000
cols: 1440
rows: 1440
e-w resol: 500
n-s resol: 500
Hello
> in Polish))
> Grass
I have:
PROJ_INFO
datum: S-42
proj: tmerc
tmerc is only used in zone V in Poland; for the other 4 zones it should
be
proj: stere
Plenty of information at
http://crs.ifag.de/country_select.php?country=PL
or ask on the PROJ.4 mailing list http://remotesensing.org/proj/
If you have GRASS 5.7 it is much easier to set up projections: try
g.proj -c proj4='+init=epsg:2171' location=poland1
g.proj -c proj4='+init=epsg:2172' location=poland2
etc. to create new locations with these projections. Should work if you
have PROJ.4 and GDAL installed properly.
Paul
On Sun, Mar 07, 2004 at 03:29:44PM +0000, Paul Kelly wrote:
Hello
> > in Polish))
> > Grass
> I have:
> PROJ_INFO
> datum: S-42
> proj: tmerc
be
proj: stere
Paul
Based in this nice feature (thanks, Paul!) I have made a new
script:
Script to create a new LOCATION from EPSG code
Usage:
   make_location_epsg_g57.sh epsg newlocation_name [GISDBASE]
       epsg: EPSG code number of projection (see /usr/local/share/proj/epsg)
       newlocation_name: new location to be created
       GISDBASE: full path to GRASS database directory (optional)
                 e.g. /ssi0/ssi/neteler/grassdata
You have to run it from *outside* GRASS.
Example:
  make_location_epsg_g57.sh 2171 poland1
does the same outside GRASS 5.7 as above 'g.proj' command line
from inside a GRASS location.
Fetch it here:
http://mpa.itc.it/grasstutor/scripts/make_location_epsg_g57.sh
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
