[GRASSLIST:3030] v.extract without centroids
Dear list,
I have two questions:
1) I imported an area shape with 6000 polygons in g57 and
there are 2 centroids missing. How can I find these two
centroids?
2) I used v.extract on this shape (with the 2 missing centroids).
v.extract in=SHAPE out=SHAPE2 type=area where='AREAQM>1'.
The areas geometry is extracted correctly but now all without centroid.
Is this because there were 2 missing in the beginning?
SHAPE
Number of nodes : 12171
Number of primitives: 15470
Number of points : 0
Number of lines : 0
Number of boundaries: 10777
Number of centroids : 4693
Number of areas : 4695
Number of isles : 1396
Number of areas without centroid : 2
SHAPE2 after using v.extract:
Number of nodes : 6602
Number of primitives: 7529
Number of lines : 0
Number of boundaries: 7529
Number of centroids : 0
Number of areas : 2300
Number of isles : 1373
Number of areas without centroid : 2300
thanks for help
  Otto
On Thursday 25 March 2004 13:36, Otto Dassau wrote:
Dear list,
centroids?
I believe that those 2 areas without centroids are slivers between
shape polygons.
Try type=area,centroid. This is not correct and it should be fixed,
type=area must export also centroids.
Radim
SHAPE
Number of lines : 0
Number of lines : 0
thanks for help
  Otto
> Dear list,
> centroids?
shape polygons.
Hi Radim,
thank you for your hint:
I used:
v.extract in=SHAPE out=SHAPE2 type=area,centroid where='AREAQM>1'.
it exports areas _and_ the centroids, but now _all_ areas,
although I just want to export areas > 1 with centroid.
Number of nodes : 6765
Number of primitives: 7692
Number of lines : 0
Number of centroids : 163
Number of areas : 2300 -> should be 163 !
Number of areas without centroid : 2137
What can be done to solve this?
  thank you
   Otto
> > Dear list,
> > centroids?
> shape polygons.
Hi Radim,
I used:
Number of lines : 0
No idea, for me it works.
Radim
