[GRASSLIST:304] Grass installation help
Hi everybody
As I am stuck in the middle I am thinking to start from the scratch including FC3 installation .So please advice me which are the packages required for GRASS from FC3.
Also I would like to know which binaries to download for FC3 from grass website. When I clicked on binaries for Fedora core 3 the following page appears - (Index of /rpm/apt/fedora/3/RPMS.mh) so know what to download from this???
Should i install source code also?
plz advice
Waiting for response.
thx
George
Jiyo cricket on Yahoo! India cricket
Yahoo! Messenger Mobile Stay in touch with your buddies all the time.
Start with
grass-6.0.0-mh3.i686.rpm
gdal-1.2.6-mh2.i686.rpm
proj-4.4.9-mh4.i686.rpm
If those complain about missing dependancies, start installing ogdi,
netcdf, etc packages as needed.
Generally not needed unless you want to do development work or use the
latest CVS. If you want to try, here's a config line which might work.
(you'll need to install a lot of -dev packages though)
Redhat 9:
CFLAGS="-g -Wall" ./configure \
    --with-motif --with-motif-includes=/usr/X11R6/LessTif/Motif1.2/include \
    --with-motif-libs=/usr/X11R6/LessTif/Motif1.2/lib \
    --with-glw --with-cxx \
    --with-freetype --with-freetype-includes=/usr/include/freetype2 \
    --without-postgres \
    2>&1 | tee config_log.txt
Hamish
