[GRASSLIST:31] v.in.dxf
Hi
I`m using grass61 on windows and would like to import dxf and dwg files,
but it is only possible with dgn files using v.in.ogr.
Is there any other possibility to do an import for AutoCad files?
thanks
Stefan Gasser
Stefan Gasser stefang@dnet.it wrote:
Yahoo! Mail
Bring photos to life! New PhotoMail makes sharing a breeze.
Stefan, you might want to take a look at OrbisCAD (please search
Google, I don't remember the URL, but I know it is in Sourceforge).
According do the authors, it can read DXF and export shapefiles.
Hope this helps
Carlos
On 3/13/06, RAVI KUMAR <ravivundavalli@yahoo.com> wrote:
Stefan Gasser <stefang@dnet.it> wrote:
Hi
I`m using grass61 on windows and would like to import dxf and dwg files, but
v.in.dwg requires OpenDWG toolkit. To get this toolkit you must become at
least "Associ! ate Member" of OpenDWG Alliance (http://www.opendwg.org), it
is free-of-charge (you have to fill one form).
Then unpack library and copy to this directory:
ad2.a ad2.h odio.h adinit.dat
and compile this module.
Ravi Kumar
thanks
Stefan Gasser
Yahoo! Mail
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Sorry for the cross-post, but I'm trying to do almost exactly the opposite. That is, export a (raster) DEM to dxf. I was browsing the diverse grass modules, and the problem is I couldn't find a way to convert a raster DEM to a vector "surface" or "3d" file. So I can later export it using v.out.dxf. I tried r.to.vect with horrible(and maybe simply "not applicable") results.
I found some (non- free) programs that seem to do this (r2v, from ablesoft, by example) but it intrigues me if it can actually be done with grass(or with free software).
Mauro
Hope this helps
Carlos
Hi
Ravi Kumar
thanks
Stefan Gasser
Yahoo! Mail
_________________
So you're trying to to export a "mesh", like a 3D vector grid of your surface?
Mauro
>Hope this helps
>Carlos
>>Hi
>>Ravi Kumar
>>thanks
>>Stefan Gasser
>>Yahoo! Mail
>_________________
_________________
(cc'ing to list)
Exactly. I can see that nviz generates this "mesh"(let's call it the "Wire" nviz Surface/Grid Surface Panel mode). But I don't know how to generate an equivalent vector map with this, from inside grass.
Mauro
Mauro
Hope this helps
Carlos
Hi
Ravi Kumar
thanks
Stefan Gasser
Yahoo! Mail
_________________
_________________
Mauro Lacy wrote:
(cc'ing to list)
Mauro
Maybe you could try r.to.vect in point mode, v.delaunay then v.out.dxf.
Laurent
Mauro
Hope this helps
Carlos
Hi
Ravi Kumar
thanks
Stefan Gasser
Yahoo! Mail
_________________
_________________
Sounds like you want a TIN. see:
http://baron.flightgear.org/pipermail/terragear-devel/2004-November/001087.html
or v.3Dtin
http://www.fle.czu.cz/~jachym/programs/grass.html
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassAddOns
Hamish
We need someone willing to write a dxf in/out module for GRASS. Using OpenDWG libraries is only a partial solution.
Michael
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
-----Original Message-----
Sent: Mon 3/13/2006 12:11 PM
To: "Carlos \"Guâno\" Grohmann"; grasslist@baylor.edu
Subject: [GRASSLIST:51] Re: v.in.dxf
Mauro
Hope this helps
Carlos
Hi
Ravi Kumar
thanks
Stefan Gasser
Yahoo! Mail
_________________
This looks promising. But seems to be work in progress:
http://www.bowdoin.edu/~ltoma/research.html
(see r.refine)
And as far as I can tell, no source code is available.
or v.3Dtin
This works! (altough v.delaunay is _extremely_ memory consuming)
After some minor corrections to v.3Dtin perl code, I was able to generate a 3D-vector TIN (altough maybe it should be more appropiately called a TRN).
I'm now stuck with the DXF file. v.out.dxf generates a valid DXF file, but it looks like 2d, not 3d.
Probably is just me :slight_smile: I'm displaying it in qcad (I don't have Autocad at hand now). And maybe I just don't know how to display it in 3D.
Mauro
Hamish
