[GRASSLIST:3124] can't display spanish DGN file
I have compiled v.in.dgn in 5.0.3 and used it to import a DGN file made by (Spain) CNIG
Import seems to be succesful. I have now dig, dig_atts & dig_cats files. But d.vect displays nothing.
I guess this is a location question, so I tried importing into different locations with different settings (I think the correct thing is Lat-Long projection, International ellipsoid, ED50 datum) whithout success
Has anyone experienced this problem?
Any help would be greatly appreciated
Roman
You might need to run v.support on the new vectors.
Try v.info, it's a good check that everything imported ok.
Set the region to the extent of the new vector file with
'g.region vect=...'
If that still doesn't work, try labelling everything with v.llabel or
v.alabel. Unlabeled vectors sometimes don't display (mostly d.vect.line
and d.vect.area).
Hamish
