Hello,
I'm working with PNG driver. The PNG driver generates PNG images from GRASS
display commands.
I have two problems
- vectors and the parts of rasters with black color are not drew on the PNG
file
- i can not set the width of the vectors.
file
Likely to be a transparency problem: have you checked the values of
GRASS_BACKGROUNDCOLOR and GRASS_TRANSPARENT ?
I don't think you can change the width of vectors with d.vect in GRASS53. Try
GRASS57, or use ps.map to get an EPS you can convert to PNG with gimp or
Imagemagick
> PNG file
I set GRASS_TRANSPARENT on or off but the result is the same: vectors and the
parts of rasters with black color are not drew on the PNG file.
I set the background color with GRASS_BACKGROUNDCOLOR but the background of
the PNG file results ever white, while the vectors and the parts of rasters
with black color are not drew.
Can you say to me how you setted GRASS_BACKGROUNDCOLOR and GRASS_TRANSPARENT
and if you reach to draw black without problems.
thank you
Try GRASS57, or use ps.map to get an EPS you can convert to PNG with gimp
