[GRASSLIST:3946] rxvt/xterm,NVIZ fonts
Can I make tcltkgrass use rxvt instead of xterm?
How do I change the fonts in NVIZ?
Maciek
[5.0/5.3]
It's mostly hardcoded, do 'cd src/tcltkgrass; grep -r xterm *' to find
them all.
[5.7]
There are only six places in 5.7 this is hardcoded:
There are three calls to xterm in main/gui.tcl, and three more in
gui/tcltkgrass/script/. Should these be changed to $env(TERM)? or is
that bad misuse of the $TERM enviro. variable? Do we then have to check
& set that TERM is set; is this just making more work for ourselves with
little benefit?
Hamish
No.
or is that bad misuse of the $TERM enviro. variable?
Yes. Seriously bad misuse.
$TERM is the name of the termcap/terminfo entry which describes the
behaviour of the terminal; it isn't the name of the program.
It's entirely possible that $TERM doesn't match the name of any
program; e.g. my xterm sessions normally have $TERM equal to
"xterm-color", but there isn't any program with that name. And most of
my shells run in an XEmacs shell-mode buffer, where $TERM is "emacs",
but running "emacs -e <program> <args>" certainly won't work.
Also, you will need more than just the program name. tcltkgrass uses
the -title, -iconic and -e switches; there's no guarantee that other
emulators will accept those switches, or will interpret them in the
same way (rxvt understands those three, but I suspect that the MacOSX
terminal probably doesn't).
Essentially, the existing occurrences of "exec xterm ..." need to be
passed to a single procedure which the user can then override (by
whatever means).
E.g.:
proc spawn_terminal {title iconic background program args} {
  set cmd {exec -- xterm}
  if {$title != ""} {lappend cmd -title $title}
  if {$iconic} {lappend cmd -iconic}
  lappend cmd -e $program
  set cmd [concat $cmd $args]
  if {$background} {lappend cmd "&"}
  eval $cmd
If you read Tcl commands from a file (e.g. ~/.tcltkgrassrc; not
~/.tcltkgrass, as that gets overwritten) after the above has been
defined, the user can redefine it if they want to use something else.
More generally, we should be trying to eliminate the use of terminals.
E.g. there's no need (AFAICT) to use an xterm for all of those d.mon
commands in menu.tcl; a Tk-based log window should suffice.
The only programs which *really* need a terminal are those which use
the Vask library or G_ask_* etc, and we should be trying our best to
either convert those to support non-interactive use or replacing them.
