[GRASSLIST:3998] Re: BoundingBox in eps not found by ps.map
thanks!
but i found the mistake myself. the eps had mac line endings, which ps.maps doesn't understand. when i changed them to unix, everything worked fine.
regards,
Florian
PS: i thought i had posted the solution the same day when i askedm but i only sned it yo myself, not to the list :slight_smile:
On Friday, July 23, 2004, at 06:26AM, Hamish <hamish_nospam@yahoo.com> wrote:
i want to include an eps file (made with adobe acrobat 6.0) into a
ps.map map, but ps.map complains that the bounding box cannot be
found. i checked the eps file and that seems to be correct as
%%BoundingBox is given.
works for me....
[tested with GRASS 5.7]
e.g. spearfish data set:
ps.map out=test.ps << EOF
raster elevation.dem
eps 50% -40%
epsfile /usr/lib/tk8.3/images/logo.eps
end
mapinfo
where 0.5 8.5
end
end
EOF
gv test.ps
here is the code, from 5.7's ps/ps.map/eps.c:
   /* looking for bbox */
   while ( fgets(buf, 200, fp) != NULL )
       if (sscanf(buf, "%%%%BoundingBox: %lf %lf %lf %lf",
  llx, lly, urx, ury) == 4)
           fclose (fp);
           return (1);
   fprintf (stderr,"Bounding box in eps file <%s> was not found\n", eps);
   fclose (fp);
   return (0);
so make sure the %%BoundingBox: statement has 4 numbers after it.
I don't know why it would fail otherwise.
Hamish
