[GRASSLIST:4095] X-windows, cygwin & GRASS
Having established that the tcltk GUI should work with GRASS on Cygwin,
I have a better understanding of my problem: As I understand it I need
to be running Xwin in full screen mode in order to start tcltkgrass.
However, if I start Xwin (in full screen mode or otherwise) Cygwin
becomes unresponsive (XWin is offering no means of inputting commands),
so I can't start tcltkgrass. As soon as Xwin is shut down, Cygwin
accepts and tries to execute any command I've tried to input while Xwin
is open.
Any ideas?
Lawrence
Cygwin,
Yes, it does.
it I need to be running Xwin in full screen mode in order to start
tcltkgrass.
You don't have to be but various things work better.
commands), so I can't start tcltkgrass. As soon as Xwin is shut down,
Cygwin accepts and tries to execute any command I've tried to input
while Xwin is open.
When you start X, the startx program has control of the Cygwin
shell-window until you exit X. It doesn't run in the background unless
you tell it to. Also, X should open up a new graphical version of
'xterm'. If not, see if it exists from the widnows start menu. You need
to launch GRASS (or any other graphics program, such as the venerable
'xeyes') from within the X environment, ie from an xterm.
Hamish
