[GRASSLIST:4113] Re: Install grass57-5.7.0-2mdk.i586.rpm
Hi all user Grass,
Thanks to Glynn Clements for helping me.
i still have a problem when installing "grass57-5.7.0-2mdk.i586.rpm"
i have already install :
fftw-2.1.5-4.1.fc2.fr.i386.rpm
gdal-1.1.9-3mdk.i586.rpm
gdal-python-1.1.9-3mdk.i586.rpm
libgdal0-1.1.9-3mdk.i586.rpm
libgrass5_0-1.0.0-1mdk.i586.rpm
proj-4.4.8-1.i386.rpm
All dependencies are already installed but why did i still find this error ?
# rpm -ihv grass57-5.7.0-2mdk.i586.rpm
error: Failed dependencies:
        libgdal.so.1 is needed by grass57-5.7.0-2mdk
# whereis libgdal.so.1
libgdal.so: /usr/local/lib/libgdal.so.1 /usr/local/lib/libgdal.so
does anyone know ???
any suggestion ?? :frowning:
sei kian
I would have expected libgdal0-1.1.9-3mdk.i586.rpm to have provided
that. What does "rpm -q --provides libgdal0" say?
Where did you get the grass57 RPM? Was there any documentation
regarding which RPMs it requires?
That doesn't matter. As I mentioned before, anything which wasn't
installed by RPM doesn't exist as far as RPM is concerned.
Hi All,
Hi,Glynn
#rpm -q --provides libgdal0
it says "
libgdal = 1.1.9
libgdal0 = 1.1.9
libgdal.1.1.so
libgdal0 = 1.1.9-3mdk
I got the grass57 RPM :
http://ftp.gwdg.de/pub/linux/mandrake/devel/cooker/contrib/i586/grass57-5.7.0-2mdk.i586.rpm
or could you tell me where can i get the complete stuff for installing
grass57 (linux mandrake)
include direction to install it.
thanks
sei kian
it says "
libgdal = 1.1.9
libgdal0 = 1.1.9
libgdal.1.1.so
I don't see a "libgdal0" package in that directory, although I do see:
libgdal1-1.2.1-1mdk.i586.rpm
libgdal1-devel-1.2.1-1mdk.i586.rpm
The only person who can provide definitive information regarding the
RPM file which you have is the person who created it. I have no idea
who that is; maybe "rpm -qi" will tell you.
all the rpms required should be available at the contrib directory on one
their ftp mirrors, eg. in case of Mdk 10:
ftp://ftp.univie.ac.at/systems/linux/Mandrake/10.0/contrib/i586/
Maciek
