[GRASSLIST:4218] attribute table
Dear list:
Here I go again. Thanks for the previous replies. I was able to move around and see my images clearly now. I am also doing on-screen digitizing.
However, I would want to know how to see the attribute data table of the polygons I digitized. Also, how can I edit and add fields in the attribute table?
Thank you for the help.
November A. Romena
attribute table?
Vector data:
Try d.what.vect to view, or 'd.what.vect -e' to edit. If you can install
QGIS, this might be easier to work with. To view a .dbf database load into an
OpenOffice or use the 'dbview -bt' utility.
Add fields in v.digit [5.7] from settings->table.
Raster data: [5.0/5.3]
v.support
[5.7] ??
Hamish
Dear Dr. Hamish & the list:
Thank you for the replies.
I am still confused how to see the attribute tables. In a commercial gis i once used, the attribute table is generated automatically after creating a polygon. There is a command option to open the attribute table and the table will pop-up when selected. The attribute table will have at least 2 important fields, feature unique id number and type. From there, I could add fields according to my data. However in using grass5.0.3, I still don't know how to open the attribute table. Is it generated automatically? Do I need to create and link a separate tabular data file?
I ran d.what.vect with the vector map containing polygons but the result was a warning and failed to see a tabular attribute data. I also ran v.support and was asked to enter values and names of categories. Still, I failed to see a tabular attribute data. I ran several routines but failed.
May I request someone from the list to provide me with idiot-friendly instructions on how to open the attribute table. Also, may I request websites where I could do some reading on attribute tables in grass5.0.3.
Thank you so much.
November
> attribute table?
Vector data:
v.support
[5.7] ??
Hamish
Let me recommend GRASS 5.7.
The vector engine and the attribute management was completely
overhauled. In GRASS 5.0.x/5.3.x you won't find a satisfying solution.
