[GRASSLIST:4390] weird lines
hello
when I use r.patch, the result map has a thin line at the joined edge of maps.
how can I eliminate these lines.
regards
Ahmet Temiz
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Ahmet,
this probably depends on the type of map that you have. You might want to reset your color table if it is a DEM. Or you might check the type of data you are patching. They might not be seamless in real life. Adjacent maps often do not match up exactly, even from the same source. If you still have a problem, tell us what kind of data you are patching.
Good luck,
Ian
On Sep 21, 2004, at 10:57 PM, temiz wrote:
hello
regards
Ahmet Temiz
