[GRASSLIST:4486] Re: DEMPSTER-SHAFER modelling
The modules should compile fine on 5.0, but really,
5.3 is much better than 5.0 and you should upgrade.
5.7 has a different vector architecture and that
caused a lot of modules to break or become obsolete.
A switch from 5.0 to 5.3 should not make anything worse.
When I get back home I will look into the possibility
of suplying ready-to-install binary modules that you
just have to copy into your GRASS 5 bin tree.
I would then upload the stuff to Michael's website
if that is alright.
Benjamin.
----- Originalnachricht -----
Von: Chavoux Luyt <educluyt@sun.ac.za>
Datum: Mittwoch, 6. Oktober 2004 10:07 pm
Betreff: Re: [GRASSLIST:4473] Re: DEMPSTER-SHAFER modelling
Thanks Benjamin!
I suppose I'll just have to wait then.
Now for a stupid question: I have both GRASS 5.0.3 and GRASS 5.7
installed (but not GRASS 5.3). Do you think I'll be able to use
the
modules with them?
To my shame (I really haven't had time), I have never looked at
the
source code of GRASS at all (so far I have just "apt-get install"
the
binary .deb packages). As I understand it, GRASS consists of a
number of
seperate executables that can be called either from the command
line or
from tcl/tk and that the initial "grass" program just set up the
environment so that these executables become available on the
current
path. In that case will I really need to recompile grass? (I don't
mind
if there is no GUI available for the modules as long as there is
enough
help files).
I'm just scared of breaking a working system when I recompile (and
I'm
quite pressed for time). I already found that some modules working
perfectly in GRASS 5.0.3 weren't working in GRASS 5.7 and that is
why I
have both installed (and use both: GRASS 5 for most raster and 3D
stuff
and GRASS 5.7 for most of the vector and database stuff).
In any case, it will be greatly appreciated if you could e-mail
them to
me. If might be good if you also e-mailed them to my yahoo e-mail,
because sometimes the University e-mail server refuse large e-
mails. It
is: Chavoux@yahoo.com
Thanks for all the trouble. Enjoy Egypt !
Greetings
Chavoux
benducke@compuserve.de wrote:
>I wrote those modules a little while ago.
>They work fine with GRASS 5.3 and can,
>in principle be used for any sort of predictive model.
>My plan is to adapt the code for GRASS 5.7 and commit
>it to the CVS version.
>I have no homepage or any place to distribute the current
>version, but will email it to you if you want it.
>Unfortunately, I am in Egypt right now and have no
>access to my progs.
>You will have to wait until I get back home at the
>start of November.
>You will also have to compile the modules yourself and
>add them to your GRASS 5.3 installation.
>Cheers,
>Benjamin
>Datum: Mittwoch, 6. Oktober 2004 5:13 pm
>Betreff: [GRASSLIST:4473] Re: DEMPSTER-SHAFER modelling
>>Hi
>>Some time ago I read about a GRASS module for archeological
>>modelling
>>using the DEMPSTER-SHAFER method. It had a link to an ESRI
webpage
>>describing the method, but used in habitat analysis on ArcView.
I
>>would
>>like to know if the GRASS module can also be used for this
purpose
>>(predicting occurence of animals from habitat factors) instead
of
>>for
>>archeology. Unfortunately I can't remember the author of the
>>module (I
>>didn't at the time think it would be usefull for my puposes).
>>Any help will be appreciated.
>>Chavoux Luyt
