[GRASSLIST:4580] Transparent null values in output images.
I have some rasters with large null areas.
I would like to output these as images (r.out.png or r.out.tiff) with the null
values represented by transparent pixels.
I can't see any flags on these commands to enable this.
Is this possible?
Regards
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
The Lord has told us what is good.
What he requires of us is this:
  to do what is just,
  to show constant love,
  and to live in humble fellowship with our God.
    -- Micah 6:8
I don't think that transparency (alpha channel?) is available for GRASS yet, though I would love to see it implemented too.
-Ian
Is this possible?
Regards
Gordon
Gordon Keith
Marine Acoustics
  to do what is just,
    -- Micah 6:8
Transparency would be particularly nice for exporting vectors. So would anti-aliasing.
Mark
Have fun or die trying - but try not to actually die.
http://www.AboveCalifornia.com
Got Mac OS X? Get the AboveCalifornia Sherlock Channel:
sherlock://www.AboveCalifornia.com/sherlock/SherlockChannel.xml?action=add
-Ian
Wanna frag? Add the ..::LVL Sherlock Channel and get the newest Quake3 maps:
sherlock://www.AboveCalifornia.com/sherlock/LVL/SherlockChannel.xml?action=add
Is this possible?
Not sure but maybe 'r.out.gdal' does that (GRASS 5.7) already?
the null values represented by transparent pixels.
Is this possible?
some clues:
set $GRASS_TRANSPARENT to "TRUE"
  then d.out.png (or d.mon start=PNG etc)
Set $GRASS_WIDTH & $GRASS_HEIGHT to region settings for cols & rows to
get 1:1 scaling (as with r.out.png).
d.out.png then merge alpha in the GIMP?
r.out.ppm -> gimp?
see the second half of this email:
  http://article.gmane.org/gmane.comp.gis.grass.devel/4943
  http://freegis.org/cgi-bin/viewcvs.cgi/grass/src/general/g.pnmcomp/
Hamish
some clues:
Where can I find a list of all environment variables
with their meaning.
Thanks, Miha
___________________________________________________________ALL-NEW Yahoo! Messenger - all new features - even more fun! http://uk.messenger.yahoo.com
with their meaning.
see the "environment variables" help pages:
http://grass.ibiblio.org/gdp/html_grass5/index.html
http://grass.ibiblio.org/grass57/manuals/html57_user/index.html
Hamish
variables
> with their meaning.
Hamish
Thanks! It is evident that I do not read the manual
pages enough!
Miha
> Is this possible?
some clues:
r.out.ppm -> gimp?
If I'm going to have to resort to GIMP it's probably easier just to use
r.out.png then GIMP:
Edit - Layers - Add alpha channel
Edit - Select - by colour - click on white
Edit - Cut (Ctrl-X)
File - Save
But it does look like
r.out.ppm raster
does the job nicely.
Thanks for pointing me in the right direction.
Thought: is it worth mentioning this in the r.out.ppm man page?
Regards
Gordon
Gordon Keith
Marine Acoustics
To mess up a Linux box, you need to work at it;
to mess up your Windows box, you just need to work on it.
- Scott Granneman, SecurityFocus
