marta.benito@uam.es wrote:
> Hello,
> please forget the last mail, ps.map works fine, but i am having problems with
> vectors:
> d.vect aalba
> segmentation fault
> an so on with other commands.
> I have tried to recompiled GRASS, and the compilation seems OK, but some vector
> commands donot work.
Thank you Radim, answering the questions
- Do you have enough space on disk?
yes
- Which module was used to write the vector,
finished without error?
no, finish with these errors:
GRASS GIS compilation log
Started compilation: lun nov 8 09:11:51 CET 2004
Errors in:
/opt/grasssources/grass57_exp_2004_01_10/display/d.zoom
/opt/grasssources/grass57_exp_2004_01_10/raster3d/r3.showdspf
/opt/grasssources/grass57_exp_2004_01_10/vector/v.vol.rst
/opt/grasssources/grass57_exp_2004_01_10/visualization/nviz
Finished compilation: lun nov 8 09:20:39 CET 2004
- GRASS was compiled on the same computer?
yes
- What files (ls -l) are in the vectors directory
($MAPSET/vector/aalba)?
ls -l especies/vector/aalba
-rw-r--r-- 1 marta marta 3673 sep 14 14:21 cidx
-rw-r--r-- 1 marta marta 91322 sep 14 14:21 coor
-rw-r--r-- 1 marta marta 53 sep 14 14:21 dbln
-rw-r--r-- 1 marta marta 145 sep 14 14:21 head
-rw-r--r-- 1 marta marta 442 sep 14 14:21 hist
-rw-r--r-- 1 marta marta 24738 sep 14 14:21 sidx
-rw-r--r-- 1 marta marta 22202 sep 14 14:21 topo
- Does it help to run v.build?
no
- The same vector vector works on other computer?
yes
- Set debug level: g.gisenv set=DEBUG=5, run the d.vect again,
and send the last 50 rows to this list.
d.vect aalba
D3/5: G_str_to_color(): str = 'black'
D3/5: G_str_to_color(): str = 'gray'
D3/5: S_read(): sname = basic/cross
D3/5: group: 'basic' name: 'cross'
D3/5: BUF: VERSION 1.0
D3/5: get_key_data(): VERSION 1.0
D3/5: key = VERSION data = 1.0
D3/5: BUF: BOX -1 -1 1 1
D3/5: get_key_data(): BOX -1 -1 1 1
D3/5: key = BOX data = -1 -1 1 1
D3/5: BUF: STRING
D3/5: get_key_data(): STRING
D4/5: STRING >
D3/5: BUF: LINE
D3/5: get_key_data(): LINE
D4/5: LINE >
D5/5: read_coor()
D3/5: get_key_data(): -1 0
D3/5: key = -1 data = 0
D5/5: x = -1.000000 y = 0.000000
D3/5: get_key_data(): 1 0
D3/5: key = 1 data = 0
D5/5: x = 1.000000 y = 0.000000
D3/5: get_key_data(): END
D5/5: LINE END
D3/5: BUF: END
D4/5: STRING END
D3/5: BUF: STRING
D4/5: STRING >
D3/5: BUF: LINE
D4/5: LINE >
D5/5: read_coor()
D3/5: get_key_data(): 0 -1
D3/5: key = 0 data = -1
D5/5: x = 0.000000 y = -1.000000
D3/5: get_key_data(): 0 1
D3/5: key = 0 data = 1
D5/5: x = 0.000000 y = 1.000000
D5/5: LINE END
D3/5: BUF: END
D4/5: STRING END
D3/5: Number of parts: 2
D4/5: Part 0: type: 1 number of chains: 1
D4/5: color: 1: fcolor: 1
D4/5: Chain 0: number of elements: 1
D4/5: Element 0: type: 1
D4/5: Number of points 2
D4/5: x, y: -1.000000 0.000000
D4/5: x, y: 1.000000 0.000000
D4/5: Part 1: type: 1 number of chains: 1
D4/5: x, y: 0.000000 -1.000000
D4/5: x, y: 0.000000 1.000000
D3/5: S_stroke(): size = 8 rotation = 0.000000 tolerance = 0
D4/5: part 0
D5/5: stroke_chain(): ch = 0
D5/5: element count = 1
D5/5: LINE count = 2
D5/5: add_coor -4, 0
D5/5: add_coor 4, 0
D4/5: part 1
D5/5: add_coor 0, -4
D5/5: add_coor 0, 4
D1/5: Vect_open_old(): name = aalba mapset= especies update = 0
D1/5: Vect_set_thresh(): thresh = 0.000000
D1/5: dig_spidx_init()
D2/5: dig_cidx_init()
D1/5: open format file: 'especies/vector/aalba/frmt'
D1/5: Vector format: 0 (native)
D1/5: Vect__read_head(): vector = aalba@especies
D1/5: Level request = 0
D1/5: Vect_open_topo(): name = aalba mapset= especies
D1/5: get coor info:
/home/marta/grassdata/espanya_modelo_devel/especies/vector/aalba/coor
D1/5: Info->size = 91322, Info->mtime = 1095164465
D2/5: Topo header: file version 5.0 , supported from GRASS version 5.0
D2/5: byte order 0
D2/5: header size 142
D2/5: with_z 0
D2/5: coor size 91322
D1/5: Topo head: coor size = 91322, coor mtime = 1073816760
D1/5: dig_load_plus()
D2/5: byte order 0
D2/5: with_z 0
segmentation fault
marta
Mensaje enviado mediante una herramienta Webmail integrada en *El Rincon*:
------------->>>>>>>> https://rincon.uam.es <<<<<<<<--------------
