[GRASSLIST:4781] how to zoom to all vectors
I am trying to locate a vector map in relation to another vector map and
need to be able to do a zoom that somehow expands the region to cover
ALL vector maps in the mapset.
Does anyone have a script that currently does this?
Ed
Crude but something along these lines has worked for me before:
for i in `g.mlist vect pa='*' sep=' '`
do
   d.vect $i
done
d.extend
d.erase
Might there be the possibility to extend
g.region
to also accept multiple raster, vector maps?
For raster the new resolution could be averaged (or the user
defines res=value).
Side effects?
g.region
defines res=value).
The boundaries case shouldn't be a problem, i.e. allow multiple maps
or region files, and set the boundary to the union of all of the
individual boundaries.
However, regarding the resolution, it should probably be left
untouched unless a single raster= or region= value is provided.
If you were to support setting the resolution in the presence of
multiple raster=/region= options, it shouldn't be the average. The
minimum resolution would be a better choice.
For "aligned" rasters, the greatest common divisor would theoretically
be the best option (i.e. if one raster had 25m resolution, and the
other 20m resolution, the region should have a 5m resolution).
However, this practical if the resolutions don't have a realistic
common divisor (if the resolutions are arbitrary floats, you could end
up with sub-nanometer resolution).
