Dear GRASS users,
I have problems with reprojecting ArcINFO rasters from UTM to LAEA. I defined LOCATION to imported the rasters (based on data provider info):
proj: utm
ellps: grs80
a: 6378137.0000000000
es: 0.0066943800
f: 298.2572221010
zone: 33
However, r.in.gdal did not import the rasters in this location, and "-o" parameter had to be used, which imported the rasters into XY location with following parameters (PROJ_INFO file is missing):
projection: 0 (x,y)
zone: 0
north: 5791545
south: 5777620
west: 3471357.5
east: 3479962.5
nsres: 5
ewres: 5
rows: 2785
cols: 1721
The target LAEA location is:
name: Lambert Azimuthal Equal Area
proj: laea
a: 6378388.0000000000
es: 0.0
f: 0.0
lat_0: 52.0000000000
lon_0: 10.0000000000
How can I reproject the files from XY location with coordinates to LAEA location? r.proj refuses to reproject XY rasters into LAEA.
Rado Bonk
Radoslav Bonk
European Commission - DG Joint Research Centre (JRC)
Institute of Environment and Sustainability (IES)
LM Unit - Natural Hazards
Via E. Fermi, TP 261, 210 20 Ispra (VA), ITALY
tel: 0039 0332 78 6013
fax: 0039 0332 78 6653
http://natural-hazards.jrc.it/floods
