Why do raster layers printed with ps.map look more
coarse (lower resolution) than ones printed with PNG
driver?
Thanks in advance
___________________________________________________________
Moving house? Beach bar in Thailand? New Wardrobe? Win £10k with Yahoo! Mail to make your dream a reality.
Get Yahoo! Mail www.yahoo.co.uk/10k
driver?
The number of raster cells used in a ps.map map is exactly the same as
the number defined by rows and columns in the g.region settings.
Make sure you have the resolution correct before creating the map.
The number of cells used by the PNG driver will be resampled to fit in
the monitor height and width, after the region resolution resampling.
So theoretically the ps.map output should generally be higher resolution
than the PNG output.. usually you can lower the region's resolution
before running ps.map and still get high quality output from a much
smaller file. Otherwise you get 40mb postscript files...
But a printed page will have finer detail than your monitor. Standard
PostScript/PDF is 72 dpi but a fine raster might print at 300 dpi.
Your monitor (PNG driver output) will generally by only ca. 800 pixels
wide, ie the same as a 2.7 inch printed version. Expand that to a full
printed page and you apparenlty lower resolution ??
PNG
> driver?
exactly the same as
g.region settings.
creating the map.
I did that.
resampled to fit in
I set the environment variables GRASS_WIDTH and
GRASS_HEIGHT to match the g.region -p output, so the
PNG file should have exactly the same number of rows
and columns as ps.map output. But even printed to
paper (same size) the maps in detail look different.
The postscript file looks more "edgy" while the png
file looks smoother. I tried to print some
topographical maps with generaly rasterized line data.
Thanks for the reply, Miha Staut
region's resolution
output from a much
files...
monitor. Standard
print at 300 dpi.
only ca. 800 pixels
Hamish
ALL-NEW Yahoo! Messenger - all new features - even more fun! http://uk.messenger.yahoo.com
> resampled to fit in
what program are you using to print out the PNG file? It is likely that
is doing some smoothing (GIMP print filters, etc.) ?
be
> > resampled to fit in
the
rows
different.
png
data.
Is it better detail or just soothness?
Hamish
I think just smoothness (printed with Photoshop 5.0).
I know that this does not regard GRASS necesarily but
also the ps2pdf command when displayed and printed
produced a kind of "preview". I will try to send you
an example but currently I can not as I am not at my
computer now.
Thanks, Miha Staut
