My computer is an Athlon(tm) 64 Processor 3000+ AuthenticAMD. Even when
the configure said that there was not any trouble, I got a set of errors.
(I am attaching the error.log file)
I already have compiled all the libraries and programs. In fact I have
running the GRASS 5.7.cvs (grass57src_cvs_snapshot_exp_2004_12_13)
without any problems.
I expect this report is being worthwhile for you
Regards
camilo
Pedro Camilo Alcántara Concepción
camilo @ pcbiol.posgrado.unam.mx
camiloalcantara @ hotmail.com
pcbiol.posgrado.unam.mx Friday Jan 14 2005 22:05:00 CST
Con el dinero se puede comprar la cama, pero no el sueño,
la comida pero no el apetito.
-- Anónim.
> (In case of errors please change into the directory with error and run 'make')
> /datos/Software/grass/bin/grass-6.0.0beta1/lib/gmath
> /datos/Software/grass/bin/grass-6.0.0beta1/lib/imagery
> /datos/Software/grass/bin/grass-6.0.0beta1/lib/rst/interp_float
and send here the output.
Radim
Pedro Camilo Alcántara Concepción wrote:
Hello
Today I visited the GRASS web page looking for the last cvs and I found
that there is not anymore the 5.7 branch but 6.0.
I compile the grass6.0 on a gentoo linux system with the following
configure line:
GRASS GIS compilation log
Started compilation: Dom Jan 16 07:34:22 BRST 2005
Errors in:
/home/samuel/grass-6.0.0beta1/lib/vector/diglib
/home/samuel/grass-6.0.0beta1/lib/vector/Vlib
/home/samuel/grass-6.0.0beta1/lib/sites
/home/samuel/grass-6.0.0beta1/lib/rst/interp_float
/home/samuel/grass-6.0.0beta1/lib/ogsf
/home/samuel/grass-6.0.0beta1/db/drivers/ogr
/home/samuel/grass-6.0.0beta1/display/d.extend
/home/samuel/grass-6.0.0beta1/display/d.path
/home/samuel/grass-6.0.0beta1/display/d.vect
/home/samuel/grass-6.0.0beta1/display/d.vect.chart
/home/samuel/grass-6.0.0beta1/display/d.what.vect
/home/samuel/grass-6.0.0beta1/display/d.zoom
/home/samuel/grass-6.0.0beta1/general/g.proj
/home/samuel/grass-6.0.0beta1/general/g.region/cmd
/home/samuel/grass-6.0.0beta1/general/manage/lib
/home/samuel/grass-6.0.0beta1/general/manage/cmd
/home/samuel/grass-6.0.0beta1/imagery/i.vpoints
/home/samuel/grass-6.0.0beta1/ps/ps.map
/home/samuel/grass-6.0.0beta1/raster/r.contour
/home/samuel/grass-6.0.0beta1/raster/r.cost
/home/samuel/grass-6.0.0beta1/raster/r.flow
/home/samuel/grass-6.0.0beta1/raster/r.le/r.le.setup
/home/samuel/grass-6.0.0beta1/raster/r.random
/home/samuel/grass-6.0.0beta1/raster/r.region
/home/samuel/grass-6.0.0beta1/raster/r.resamp.rst
/home/samuel/grass-6.0.0beta1/raster/r.to.vect
/home/samuel/grass-6.0.0beta1/raster/r.in.gdal
/home/samuel/grass-6.0.0beta1/vector/v.buffer
/home/samuel/grass-6.0.0beta1/vector/v.build
/home/samuel/grass-6.0.0beta1/vector/v.build.polylines
/home/samuel/grass-6.0.0beta1/vector/v.category
/home/samuel/grass-6.0.0beta1/vector/v.clean
/home/samuel/grass-6.0.0beta1/vector/v.convert
/home/samuel/grass-6.0.0beta1/vector/v.db.connect
/home/samuel/grass-6.0.0beta1/vector/v.db.select
/home/samuel/grass-6.0.0beta1/vector/v.digit
/home/samuel/grass-6.0.0beta1/vector/v.distance
/home/samuel/grass-6.0.0beta1/vector/v.extract
/home/samuel/grass-6.0.0beta1/vector/v.hull
/home/samuel/grass-6.0.0beta1/vector/v.info
/home/samuel/grass-6.0.0beta1/vector/v.in.ascii
/home/samuel/grass-6.0.0beta1/vector/v.in.db
/home/samuel/grass-6.0.0beta1/vector/v.in.region
/home/samuel/grass-6.0.0beta1/vector/v.in.sites
/home/samuel/grass-6.0.0beta1/vector/v.kcv
/home/samuel/grass-6.0.0beta1/vector/v.kernel
/home/samuel/grass-6.0.0beta1/vector/v.label
/home/samuel/grass-6.0.0beta1/vector/v.proj
/home/samuel/grass-6.0.0beta1/vector/v.mkgrid
/home/samuel/grass-6.0.0beta1/vector/v.neighbors
/home/samuel/grass-6.0.0beta1/vector/v.net
/home/samuel/grass-6.0.0beta1/vector/v.net.alloc
/home/samuel/grass-6.0.0beta1/vector/v.net.iso
/home/samuel/grass-6.0.0beta1/vector/v.net.path
/home/samuel/grass-6.0.0beta1/vector/v.net.salesman
/home/samuel/grass-6.0.0beta1/vector/v.net.steiner
/home/samuel/grass-6.0.0beta1/vector/v.normal
/home/samuel/grass-6.0.0beta1/vector/v.out.ascii
/home/samuel/grass-6.0.0beta1/vector/v.out.dxf
/home/samuel/grass-6.0.0beta1/vector/v.out.pov
/home/samuel/grass-6.0.0beta1/vector/v.overlay
/home/samuel/grass-6.0.0beta1/vector/v.patch
/home/samuel/grass-6.0.0beta1/vector/v.perturb
/home/samuel/grass-6.0.0beta1/vector/v.qcount
/home/samuel/grass-6.0.0beta1/vector/v.random
/home/samuel/grass-6.0.0beta1/vector/v.reclass
/home/samuel/grass-6.0.0beta1/vector/v.sample
/home/samuel/grass-6.0.0beta1/vector/v.segment
/home/samuel/grass-6.0.0beta1/vector/v.select
/home/samuel/grass-6.0.0beta1/vector/v.surf.idw
/home/samuel/grass-6.0.0beta1/vector/v.surf.rst
/home/samuel/grass-6.0.0beta1/vector/v.transform
/home/samuel/grass-6.0.0beta1/vector/v.to.db
/home/samuel/grass-6.0.0beta1/vector/v.to.points
/home/samuel/grass-6.0.0beta1/vector/v.to.rast
/home/samuel/grass-6.0.0beta1/vector/v.type
/home/samuel/grass-6.0.0beta1/vector/v.univar
/home/samuel/grass-6.0.0beta1/vector/v.voronoi
/home/samuel/grass-6.0.0beta1/vector/v.what.rast
/home/samuel/grass-6.0.0beta1/vector/v.vol.rst
/home/samuel/grass-6.0.0beta1/vector/v.out.ogr
/home/samuel/grass-6.0.0beta1/vector/v.in.ogr
/home/samuel/grass-6.0.0beta1/vector/v.external
/home/samuel/grass-6.0.0beta1/visualization/nviz
Finished compilation: Dom Jan 16 07:36:03 BRST 2005
changed into /visualization/nviz
run make
error message:
cd src ; make
make[1]: Entering directory
`/home/samuel/grass-6.0.0beta1/visualization/nviz/src'
gcc -I/home/samuel/grass-6.0.0beta1/include
-I/home/samuel/grass-6.0.0beta1/dist./include/grass
-g -Wall -Wall -Wconversion -Wno-implicit-int
-I/usr/X11R6/include -I/usr/include/tcl8.3
-D_NO_PROTO -D__STDC__ -I/usr/include
-DPACKAGE=\""grassmods"\"
-I/home/samuel/grass-6.0.0beta1/dist./include/grass \
-o OBJ./nvizAppInit.o -c nvizAppInit.c
<command line>:5:1: warning: "__STDC__" redefined
In file included from nvizAppInit.c:9:
interface.h:22:19: gsurf.h: No such file or directory
interface.h:23:21: gstypes.h: No such file or
directory
interface.h:86: error: `MAX_CPLANES' undeclared here
(not in a function)
interface.h:87: error: `MAX_CPLANES' undeclared here
(not in a function)
interface.h:88: error: `MAX_CPLANES' undeclared here
(not in a function)
interface.h:90: error: `MAX_LIGHTS' undeclared here
(not in a function)
nvizAppInit.c:43: warning: `RunScripts' defined but
not used
make[1]: *** [OBJ./nvizAppInit.o] Error 1
make[1]: Leaving directory
make: *** [nvwish] Error 2
_______________________________________________________
Yahoo! Acesso Grátis - Instale o discador do Yahoo! agora. http://br.acesso.yahoo.com/ - Internet rápida e grátis
run 'make')
gcc -I/datos/Software/grass/bin/grass-6.0.0beta1/include
-I/datos/Software/grass/bin/grass-6.0.0beta1/dist.x86_64-unknown-linux-gnu/include/grass
-g -Wall -Wall -Wconversion -Wno-implicit-int -fPIC
-DPACKAGE=\""grasslibs"\" -DPACKAGE=\""grasslibs"\"
-o OBJ.x86_64-unknown-linux-gnu/fft.o -c fft.c
fft.c: In function `fft':
fft.c:40: error: `fftwnd_plan' no se declaró aquí (primer uso en esta
función)
fft.c:40: error: (Cada identificador no declarado solamente se reporta una
vez
fft.c:40: error: para cada funcion en la que aparece.)
fft.c:40: error: error de decodificación antes de "plan"
fft.c:45: aviso: al pasar el argumento 1 de `sqrt' como coma flotante en
lugar de entero debido al prototipo
fft.c:47: aviso: al pasar el argumento 1 de `G_malloc' con anchura
diferente debido al prototipo
fft.c:51: error: petición del miembro `re' en algo que no es estructura ó
unión
fft.c:52: error: petición del miembro `im' en algo que no es estructura ó
unión
fft.c:55: error: `plan' no se declaró aquí (primer uso en esta función)
fft.c:55: aviso: declaración implícita de la función `fftw2d_create_plan'
fft.c:58: error: `FFTW_IN_PLACE' no se declaró aquí (primer uso en esta
función)fft.c:60: aviso: declaración implícita de la función `fftwnd_one'
fft.c:62: aviso: declaración implícita de la función `fftwnd_destroy_plan'
fft.c:66: error: petición del miembro `re' en algo que no es estructura ó
unión
fft.c:67: error: petición del miembro `im' en algo que no es estructura ó
unión
make: *** [OBJ.x86_64-unknown-linux-gnu/fft.o] Error 1
run 'make')
Radim
> Hello
> configure line:
> CFLAGS="-g -Wall" ./configure --with-gdal=/usr/local/bin/gdal-config --en
> able-64bit --with-fftw-libs=/usr/lib/ --with-lapack-libs=/usr/lib/
> --with-lapac k=yes --with-freetype=yes --with-freetype-libs=/usr/lib64/
> --with-freetype-incl udes=/usr/include/freetype2/
> Regards
> camilo
> Started compilation: vie ene 14 17:11:14 CST 2005
> Errors in:
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.class
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.cluster
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.gensig
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.gensigset
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.group
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.his.rgb
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.maxlik
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.ortho.photo/libes
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.ortho.photo/menu
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.ortho.photo/photo.2image
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.ortho.photo/photo.2target
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.ortho.photo/photo.camera
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.ortho.photo/photo.elev
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.ortho.photo/photo.init
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.ortho.photo/photo.rectify
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.ortho.photo/photo.target
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.points
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.rectify
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.rgb.his
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.smap/shapiro
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.target
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.vpoints
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.cca
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.fft
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.ifft
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.pca
> /datos/Software/grass/bin/grass-6.0.0beta1/imagery/i.zc
> /datos/Software/grass/bin/grass-6.0.0beta1/ps/ps.map
> /datos/Software/grass/bin/grass-6.0.0beta1/raster/r.param.scale
> /datos/Software/grass/bin/grass-6.0.0beta1/raster/r.resamp.rst
> /datos/Software/grass/bin/grass-6.0.0beta1/raster/r.in.gdal
> /datos/Software/grass/bin/grass-6.0.0beta1/raster/r.surf.fractal
> /datos/Software/grass/bin/grass-6.0.0beta1/raster/r.surf.gauss
> /datos/Software/grass/bin/grass-6.0.0beta1/raster/r.surf.random
> /datos/Software/grass/bin/grass-6.0.0beta1/vector/v.kernel
> /datos/Software/grass/bin/grass-6.0.0beta1/vector/v.surf.rst
> Finished compilation: vie ene 14 17:16:06 CST 2005
pcbiol.posgrado.unam.mx Saturday Jan 15 2005 08:05:00 CST
Lo más incomprensible acerca de este mundo es que es comprensible.
-- Albert Einstein. (1879-1955) Físico alemán.
directory
two header files gsurf.h and gstypes.h were not found.
well, in fact no error after the “./configure”…that error log i reported is only after the “make” command…so no dependencies problems i guess…
i had compiled grass54 with no problems…
with grass6 beta1 there are new packages to be installed before?
thanks
thanks
> i tried to compile grass6 beta1 but there were errros
> in so many modules...
> after the log message i changed into mentioned
> directories (some of them) but it didn't work as
> well...
> i'm using debian based XandrOS
> --with-tcltk-includes=/usr/include/tcl8.3
> =/usr/include/tk8.3 --without-postgres --without-odbc
> Errors in:
.. if the libraries don't compile, anything that needs them won't
either. Best to start looking for what is broken there first.
> directory
