I was wondering is it not possible to specify a variable in the
neighbourhood modifier in r.mapcalc. E.g. I can write map[2,-1] but if
I write something like map[offsetrow,offsetcolumn] I get:
parse error, unexpected `VARNAME', expecting `INTEGER' or `'-''
Parse error
Is there a good reason for this / would it be possible to change it, or
does anybody know a workaround for specifying the contents of any
arbitrary cell using variables?
Thanks in advance for any ideas
Paul
Parse error
What sort of variable?
Bear in mind that r.mapcalc's "variables" are effectively entire maps;
the value may change from cell to cell.
If you are thinking in terms of scripting, you can just use the
shell's variables e.g.
offsetrow=2
offsetcolumn=-1
r.mapcalc "out = map[$offsetrow,$offsetcolumn]"
OTOH, if you want something that will vary over the course of the
evaluation, then it isn't possible, and it isn't really feasible to
change r.mapcalc to make it possible.
